It is currently Mon Nov 16, 2026 1:17 am
 Page 1 of 1 [ 9 posts ]
 Post subject: Emissions inspection
PostPosted: Thu Jul 12, 2007 12:14 pm
My '89 Custom Cruiser was due for an inspection this month, so I took it to the DMV, and I failed for emissions.
It's got the Olds 307, one of the computer controlled late model Q-jets, stock (and somewhat rusty) manifolds, crosspipe, and cat. From the catback is a relatively new B-pipe (the 4' long pipe going from the cat to the muffler, not sure what it's called on the Olds, my Maxima and Oldsmobile jargon get mixed up sometimes) and muffler and tailpipe.
Is there anything I can do short of major parts replacement to get it working? Some way to clean out the cat, or a way to tweak the Q-jet to run really lean and clean temporarily? I don't have the tools to change the cat myself unless it's easier than it looks, and I don't want to pay $500 for a shop to switch it out.
 Post subject: Re: Emissions inspection
PostPosted: Thu Jul 12, 2007 7:35 pm
nalc wrote:
........ I took it to the DMV, and I failed for emissions ........
What was the reason given?
307 has been on the ragged edge, from the beginning.
If the entire emissions system is working properly, it can fail simply because it needs plugs/wires/cap/rotor, a new air filter, or an oil change.
If it is not, the cause might be something as simple as, a TPS that needs adjustment, or replacement.
........ my Maxima and Oldsmobile jargon get mixed up sometimes ........
Don't get caught up in "jargon", it only confuses the issue. If it's a stock system, say so. If it's not, it is possible that's the reason it failed.
........ Is there anything I can do short of major parts replacement to get it working? ........
No way to know the cure, without knowing the cause.
........ or a way to tweak the Q-jet to run really lean and clean temporarily? ........
By design, a CCC 307 runs best, and cleanest, when the carb is adjusted according to its Factory Service Manual. It spells out a multi step procedure that must be followed exactly.
........ and I don't want to pay $500 for a shop to switch it out.
For only the converter? If that is the price you were quoted, find another shop.
PostPosted: Sun Jul 15, 2007 4:10 pm
My CO was at 3.3%, pass was 0.7%
My hydrocarbons were at 187 parts, pass was 128
It's not stock. The stock muffler rusted out before I even purchased the car, and the stock B-pipe rusted out about a year ago. The only parts still stock (as far as I know), are the headers, crossover pipe, and cat.
Do I need any special tools to adjust it?
PostPosted: Sun Jul 15, 2007 5:45 pm
I would start with a full engine tuneup and have it tested again- If you haven't tuned it up yet, then it probably needs it anyway-
JMHO
PostPosted: Mon Jul 16, 2007 1:00 am
What exactly would that entail?
I think I forgot to mention it, but I'm selling it. So I'm not too keen on spending money on improvements, being that I've already received offers for it in its current condition. I already washed out the air filter. I don't really have any tools, or any experience. I know it's probably stupid, but I came looking for a cheap fix. If there's not going to be a way that I can fix it cheap, please tell me, because then I won't fix it at all.
PostPosted: Mon Jul 16, 2007 1:02 am
My hydrocarbons were at 187 parts, pass was 128 ........
Not what I was looking for. I can assume, that they did not tell you the nature of the problem. IE: a faulty CAT, sensor, ignition, contaminated oil, or a fuel delivery problem.
From the numbers given, I suspect a vacuum leak.
........ The stock muffler rusted out before ........
If the muffler was replaced with an OEM type, it would still be a stock system, and it would not be a factor.
No need to replace the CAT, unless it has been proven to be defective.
........ The only parts still stock (as far as I know), are the headers, crossover pipe, and cat ........
I'm assuming you mean manifolds, not headers, because of your reference to the crossover pipe.
Rust is not a factor, unless it's serious enough to cause exhaust leaks, which are another cause for failure.
........ Do I need any special tools to adjust it?
If you mean the carb, the FSM will tell you what tools you will need, along with giving you the instructions needed for an accurate adjustment. If it has not been molested in any way, odds are, it does not need adjustment.
Beware: If those instructions are not followed to the letter (exactly) it will fail the test.
I would start with a full engine tuneup ........
Including replacement of the the air and fuel filters, and don't forget the the oil/filter change.
PostPosted: Mon Jul 16, 2007 7:41 pm
Has anyone seen or heard anything about those additives "guaranteed to make any vehicle pass"... Not certain on any specific product's name, but I was humorously reading one such bottle a few months ago in canadian tire. I wonder what it does, and if it works?
PostPosted: Fri Jul 20, 2007 12:56 pm
I took it into the shop where I get all my work done. They adjusted the M/C solenoid and one or two other things and passed it. I'm good until 2009.
PostPosted: Wed Jul 25, 2007 7:07 pm
Good show.
