It is currently Fri Nov 06, 2026 12:26 pm
s0ad
 Posted: Wed Aug 22, 2007 6:46 pm |
So this is a long story, and I'm going to try to make it short for you guys. I have a 1989 Delta88 Royale v6 3800. About 2 weeks ago I noticed a leak in my engine bay. Turns out it was a fuel line leaking. It was the back line that hooks into the top of the engine. Well, I thought I could just replace that line, so I went and bought a replacement at the GM dealer. Turns out, that shit was WAY rusted and corroded, so I really couldn't take it apart. So then I tried disconnecting it from the fuel filter, but that was a no-go because of rust also. Then I decided to drop the gas tank and try to disconnect the line directly from the tank. Turns out I can't do that either because of the smartass engineers at GM that decided to run the fuel lines directly into the fuel pump, smartasses.
So because of all these problems (the rust and everything else), I've decided to just take out the whole line, from front to back, and replace everything. So I need some specific diagrams or schematics or something for the fuel system and the brake system, because I'll also have to probably replace some brake lines due to corrosion and rust.
 Posted: Thu Aug 23, 2007 10:29 am |
91parkave
 Posted: Thu Aug 23, 2007 10:18 pm |
s0ad wrote: So this is a long story, and I'm going to try to make it short for you guys. I have a 1989 Delta88 Royale v6 3800. About 2 weeks ago I noticed a leak in my engine bay. Turns out it was a fuel line leaking. It was the back line that hooks into the top of the engine. Well, I thought I could just replace that line, so I went and bought a replacement at the GM dealer. Turns out, that shit was WAY rusted and corroded, so I really couldn't take it apart. So then I tried disconnecting it from the fuel filter, but that was a no-go because of rust also. Then I decided to drop the gas tank and try to disconnect the line directly from the tank. Turns out I can't do that either because of the smartass engineers at GM that decided to run the fuel lines directly into the fuel pump, smartasses.
i wouldnt go the extreme of replacing the lines, the fuel filter thing is common even in 2000 cars. as for your leak where exactly was it leaking from? if i were you id take it ti the shop and have them install a new fittings for you. bring the fittings and line with you though so all you have to do is pay labor and the brake lines..go buy some rust converter or naval jelley from your local auto parts store, that should take car of the surface rust then just clean the area up and spray with rust proof primer.
 Posted: Thu Aug 23, 2007 10:46 pm |
91parkave wrote: s0ad wrote: So this is a long story, and I'm going to try to make it short for you guys. I have a 1989 Delta88 Royale v6 3800. About 2 weeks ago I noticed a leak in my engine bay. Turns out it was a fuel line leaking. It was the back line that hooks into the top of the engine. Well, I thought I could just replace that line, so I went and bought a replacement at the GM dealer. Turns out, that shit was WAY rusted and corroded, so I really couldn't take it apart. So then I tried disconnecting it from the fuel filter, but that was a no-go because of rust also. Then I decided to drop the gas tank and try to disconnect the line directly from the tank. Turns out I can't do that either because of the smartass engineers at GM that decided to run the fuel lines directly into the fuel pump, smartasses.
So because of all these problems (the rust and everything else), I've decided to just take out the whole line, from front to back, and replace everything. So I need some specific diagrams or schematics or something for the fuel system and the brake system, because I'll also have to probably replace some brake lines due to corrosion and rust. i wouldnt go the extreme of replacing the lines, the fuel filter thing is common even in 2000 cars. as for your leak where exactly was it leaking from? if i were you id take it ti the shop and have them install a new fittings for you. bring the fittings and line with you though so all you have to do is pay labor and the brake lines..go buy some rust converter or naval jelley from your local auto parts store, that should take car of the surface rust then just clean the area up and spray with rust proof primer.
So if the line is so corroded that the fitting won't turn, you don't need to replace the line?
If it's worth doing, its worth doing right. Saving money hardly ever saves you money, and rust converter doesn't make corroded metal come back.
If the car was 7 years old, it might be a point worth making, but it's 18 years old. Good luck finding a shop that will put new fittings on old lines.
This forum does not need your BS replies.
91parkave
 Posted: Thu Aug 23, 2007 11:48 pm |
andrewk wrote: So if the line is so corroded that the fitting won't turn, you don't need to replace the line? yes smart one cut it befor the fitting, double flare it and install new fitting. andrewk wrote: If it's worth doing, its worth doing right. Saving money hardly ever saves you money, and rust converter doesn't make corroded metal come back. oh really you have personal experience? i used it on 2 of my cars used the naval jelley, wiped that off sanded a little and sprayed rust proof primer,or rust converter. Rust cant spread if there is no oxygen able to get to it in case you didnt know. andrewk wrote: If the car was 7 years old, it might be a point worth making, but it's 18 years old. Good luck finding a shop that will put new fittings on old lines. it wouldnt matter andrew rust is rust rather 3yrs old or 40yrs old. andrewk wrote: This forum does not need your BS replies.
This coming from somebody who needs advice about engine mounts? your whole post dosent add much if anything to help. especially since you obviously have no experience with rust chems. and such, so how can you talk?....now lets begin another quote fest with you and your friends
s0ad
 Posted: Fri Aug 24, 2007 12:10 am |
The leak was where the metal part of the fuel line connects to the engine block and then transfers to rubber. The rubber part had a hole from I suspect heat wear and old age. My car is in such dismemberment at the moment that I couldn't take it to a shop without having to play for a flat-bed. Finally, the rust is so bad on some of these lines, especially this brake line in the back, that it really does need to be replaced now that I have seen it and have access to it. It would be stupid of me to just try a cosmetic fix on these lines, especially this brake line, being that it is a frickin brake line.
 Posted: Fri Aug 24, 2007 12:47 am |
91parkave wrote: oh really you have personal experience? i used it on 2 of my cars used the naval jelley, wiped that off sanded a little and sprayed rust proof primer,or rust converter. Rust cant spread if there is no oxygen able to get to it in case you didnt know. The damage is done. Naval jelly doesn't produce metal molecules. Quote: your whole post dosent add much if anything to help. Only to warn him your advice is stupid. It worked. Quote: especially since you obviously have no experience with rust chems. and such, so how can you talk? One only needs to know one thing about them- They don't make metal. What rust has eroded away, is gone, turned into oxidized flakes or powder. POR or any other rust converter, chemical, Naval Jelly, etc will not build up what metal is now gone. Quote: ....now lets begin another quote fest with you and your friends
The thread will be locked before that happens again. Consider that a final warning.
s0ad wrote: 91parkave wrote: s0ad wrote: So this is a long story, and I'm going to try to make it short for you guys. I have a 1989 Delta88 Royale v6 3800. About 2 weeks ago I noticed a leak in my engine bay. Turns out it was a fuel line leaking. It was the back line that hooks into the top of the engine. Well, I thought I could just replace that line, so I went and bought a replacement at the GM dealer. Turns out, that shit was WAY rusted and corroded, so I really couldn't take it apart. So then I tried disconnecting it from the fuel filter, but that was a no-go because of rust also. Then I decided to drop the gas tank and try to disconnect the line directly from the tank. Turns out I can't do that either because of the smartass engineers at GM that decided to run the fuel lines directly into the fuel pump, smartasses.
So because of all these problems (the rust and everything else), I've decided to just take out the whole line, from front to back, and replace everything. So I need some specific diagrams or schematics or something for the fuel system and the brake system, because I'll also have to probably replace some brake lines due to corrosion and rust. i wouldnt go the extreme of replacing the lines, the fuel filter thing is common even in 2000 cars. as for your leak where exactly was it leaking from? if i were you id take it ti the shop and have them install a new fittings for you. bring the fittings and line with you though so all you have to do is pay labor and the brake lines..go buy some rust converter or naval jelley from your local auto parts store, that should take car of the surface rust then just clean the area up and spray with rust proof primer. The leak was where the metal part of the fuel line connects to the engine block and then transfers to rubber. The rubber part had a hole from I suspect heat wear and old age. My car is in such dismemberment at the moment that I couldn't take it to a shop without having to play for a flat-bed. Finally, the rust is so bad on some of these lines, especially this brake line in the back, that it really does need to be replaced now that I have seen it and have access to it. It would be stupid of me to just try a cosmetic fix on these lines, especially this brake line, being that it is a frickin brake line.
Good choice- Let us know how it turns out!
