If anyone knows what the torque spec for the lower control arm bolts are I could use some help! I can't find them online and I'm still waiting for my service manuals to come. Any help or direction would be appreciated,
I can probably tell you what it is, but I am away from my computer...which has all the info on it. Should be able to tell ya before the end of this weekend.
P.S. You posted this topic in the forum tech support...which is for help with the forum itself. I moved it to maintenance.
Control Arm: Specifications Front:
Control Arm Front Nut ...................................................................................................................................................................... 126 Nm (93 ft. lbs.)
Control Arm Rear Bolt .................................................................................................................................................................... 158 Nm (117 ft. lbs.)
Rear:
Control Arm Nuts .............................................................................................................................................................................. 106 Nm (78 ft. lbs.)
