 Page 1 of 3 [ 33 posts ]  Go to page 1, 2, 3  Next
 Post subject: No Blower Function
PostPosted: Tue Sep 11, 2007 7:20 pm
Hey,
1995 Eighty Eight LS with no apparent blower function. Car has digital climate control which seems to work fine, but there is no air flow or noise to indicate that the blower is working at all. The different vent options sound like they switch open when I touch each different button, but still, no air at all from anywhere. Any advice? The car hasn't been used in about six months so things might have become stuck. Where and how do I gain access to the blower motor? Anything I might try with this?
Thanks
 Post subject: Re: No Blower Function
PostPosted: Tue Sep 11, 2007 7:57 pm
OldsBuickGuy82 wrote:
........ no apparent blower function .......
Check for power at the motor.
PostPosted: Tue Sep 11, 2007 8:22 pm
I also noticed that when I start the car, the temp on the screen will flash on and off. I read a while back that is something to do with error codes in the climate control unit. Is that correct?
PostPosted: Tue Sep 11, 2007 9:07 pm
........ when I start the car, the temp on the screen will flash on and off ........
It is supposed to go on when the switch is in the start position. This is to verify the light/sensor system is functioning properly.
........ that is something to do with error codes ........
Have you seen any error codes?
How would any error codes, tell us whether you have power to the motor, or not?
PostPosted: Tue Sep 11, 2007 10:20 pm
PostPosted: Tue Sep 11, 2007 10:40 pm
88 Coupe, no, I haven't seen any codes, I was just wondering if climate error could be determined via the screen on the unit as I had read about on another forum. That's all. And I do realize that the presence of such a code wouldn't tell you much about power to the blower motor or not.
This is the thread where I read about the flashing indicating an error. 1st reply.
http://www.automotiveforums.com/vbullet ... p?t=477184
"the temperature display is blinking because there are error codes stored somewhere in your temperature control system. to clear these, unhook your negative battery terminal then turn the ignition or lights on to drain power from the system. this will reset the controller, therefore erasing the codes."
Brando, thank you for posting that diagram. It's very helpful to a novice.
Cheers
PostPosted: Wed Sep 12, 2007 2:10 am
........ 1st reply.
the temperature display is blinking because there are error codes stored ........
From the opening post:
........ the temperature display on the dash blinks 20 times or so when is start the car, then it stays on ........
From your post:
........ when I start the car, the temp on the screen will flash on and off .........
I see two different descriptions. Which one better fits your situation?
Be advised that internet diagnosis is difficult enough when there is accurate communication. Unless both parties are speaking the same language, it is impossible.
PostPosted: Wed Sep 12, 2007 12:13 pm
What 2 descriptions do you see? I see only one. That is, that the temperature on the climate control until blinks when the car is started. Are you taking one to mean the engine temperature as displayed next to the speedometer, and the other to mean the temperature on the climate control unit?
PostPosted: Wed Sep 12, 2007 1:29 pm
What 2 descriptions do you see? ........
These.
........ will flash on and off .........
automotiveforums.com wrote:
........ blinks 20 times or so ........ then it stays on ........
Two very different descriptions.
Successful diagnosis, often depends on recognizing small differences such as these.
PostPosted: Wed Sep 12, 2007 3:50 pm
I see what you mean. It seems it just continues to flash without stopping until I adjust the fan speed. I counted 40+ flashes then I changed the setting.
PostPosted: Wed Sep 12, 2007 6:51 pm
did you try unhooking the negative battery cable to reset the climate controller, like the poster recommended?
PostPosted: Wed Sep 12, 2007 7:45 pm
No I didn't try it. I guess I'll be taking it in to the garage in the next week anyway so I'll just let them work it out. Think there is any chance that might correct the problem though?
PostPosted: Thu Sep 13, 2007 10:44 pm
It's worth a try...nothing to lose really.
PostPosted: Mon Oct 15, 2007 3:57 pm
I finally got around to picking up a new blower motor, but there is still no function at all. The climate control unit appears to work as it should when adjusting the settings and temp, and the rear defrost works too. I disconnected the battery thinking it might need to reset, connected it again and went for a short drive. Still nothing. I had a friend test the plug in connector to the blower and then turn the fan on and off from the inside and there was power going to the fan. If it was a resistor or a relay wouldn't that stop power getting to the fan?
Any ideas?
PostPosted: Mon Oct 15, 2007 9:12 pm
I finally got around to picking up a new blower motor, but there is still no function at all.....
.... I had a friend test the plug in connector to the blower and then turn the fan on and off from the inside and there was power going to the fan...
If there is power at the FAN connector, the fan should run. Did you have your friend test the ground on that connector also? If there is power, and you have installed a new blower (unless DOA) that blower should be blowin'.
Did you happen to ask what voltages he found at off and high speed?
