It is currently Fri Nov 06, 2026 12:26 pm
 Posted: Wed Sep 12, 2007 2:30 pm |
91buickman wrote: 2ROCKETS73 wrote: ........ What does odd fire and even fire engines mean? ........ ........ odd-fire is a refrence to the firing order ........ Does not answer his question. 91buickman wrote:
This doesn't either.
Rockets: They used a different crankshaft design and replaced the the V8 distributor with one designed for the V6.
I'm working on a more specific answer.
 Posted: Wed Sep 12, 2007 2:43 pm |
Quote: They used a different crankshaft design. I am working on a more specific answer.
Thanks Norm- I was also working on one, but I will let you take care of it, as school leaves me little time to compose-
 Posted: Wed Sep 12, 2007 2:51 pm |
I was thinking This one would save me a little time, but it was no more than a sidebar.
Added the tidbit, about the distributor, above while you posted.
 Posted: Wed Sep 12, 2007 4:38 pm |
buickman wrote: http://www.novak-adapt.com/knowledge/buick_90_v6.htm http://home.off-road.com/~merls_garage/oddfire.html
Already checked both, since they are at the top of Google's returns. They did not have what I needed.
They are, however, about as accurate as one will find on the internet.
 Posted: Thu Sep 13, 2007 9:20 am |
91parkave wrote: yea odd-fire is a refrence to the firing order sequence of the engine, Firing order has nothing to do with it. Odd-fire and even-fire (231's) have the same firing order, 1-6-5-4-3-2. It is odd-fire, because of the crankshaft design is derived from the V8, instead of being redesigned to suit a 6 cylinder engine. This is from Wiki, and I can't think of a better way to say it- Article can be found hereWiki wrote: Many older V6 engines were been based on V8 engine designs, without altering the V angle or using a more sophisticated crankshaft to even out the firing interval. One characteristic of these engines was a notorious odd-firing behavior.
Purpose-built V6 engines use one crankpin per cylinder for an even 120° ignition pattern. In contrast, most V8 engines share a common crankpin between opposite cylinders in each bank. That is, the crankshaft has just four pins for eight cylinders, and a cylinder fires every 90° for smooth operation.
V6 engines derived from V8 engines often have three shared crankpins arranged at 120° from each other, similar to an inline 3-cylinder, with two pistons per crankpin. If the cylinder banks are arranged at 90° (as they commonly are in V8-derived V6s), this leads to a firing pattern with groups of two cylinders separated by 90° of rotation, and groups separated by 150° of rotation.
An example is the Buick 231 odd-fire, which has a firing order 1-6-5-4-3-2. As the crankshaft is rotated through the 720° required for all cylinders to fire.....
Then this- Wiki wrote: In 1977, Buick introduced a new "split-pin crankshaft" in the 231. Using a crankpin that is 'split' and offset by 30° of rotation resulted in smooth, even firing every 120°. However, in 1978 Chevrolet introduced a 90° 200/229 V6, which had a compromise 'semi-even firing' design using a crankpin that was offset by only 18°. This resulted in cylinders firing at 108° and 132°, which had the advantage of reducing vibrations to a more acceptable level and did not require strengthening the crankshaft. In 1985 Chevrolet changed it to a true even-firing V6 with a 30° offset, requiring larger crank journals to make them adequately strong.
In 1986 the similarly-designed 90° PRV engine adopted the same 30° crankshaft offset design to even out its firing. Most recent 90° V6 designs use split crankpins to even out the firing intervals. Such a 'split' crankpin is weaker than a straight one, but modern metallurgical techniques can produce a crankshaft that is adequately strong.
Hope this helps-
91parkave
 Posted: Thu Sep 13, 2007 10:11 am |
yea what are you r trying to know because from the 2 links i posted and other reasearch is that they have diffrent firing impulses , and various engine parts
odd fire:
The cylinder numbering for the odd-fire V6 is 1-3-5 from the front down the driver's side, and 2-4-6 down the passenger side. The firing order is 1-6-5-4-3-2.
The Dauntless 225 and the odd-fire Buick 231 have a crankshaft with three journals that are offset at 120 degree intervals.Looking at the front of the crankshaft you would see the front journals at the noon position on a clock, the middle journal at the eight o'clock position, and the rear journal at 4 o'clock.
Each of the three journals are shared by two pistons. The front journal is shared by cylinders 1 and 2, the middle shares 3 and 4, and the rear shares 5 and 6. Keep in mind that this means if one piston is fully extended towards the cylinder head, the other piston that shares that journal will not be.
This is a 90 degree V6, meaning that the two banks of cylinders are at 90 degrees to each other. Most V8 and some other V6 engines are also built at 90 degrees, but logic would dictate that 60 degrees would be more natural for a V6. For example the 2.8L V6 used in some late model cars is a 60 degree engine.
Since each journal is shared by two pistons, if one piston is fully extended towards the cylinder head the other piston sharing that journal will not be. For example, with number two fully extended number one will not be fully extended until the crankshaft rotates another 90 degrees (since the cylinder banks are at 90 degrees to each other).
The distributor shaft and rotor will make one complete rotation for every two rotations that the crankshaft makes.
Since an engine crankshaft always rotates twice per ignition cycle, most of the information here is presented as 0 to 720 degrees rather than just 0 to 360. The 720 degrees represents two complete rotations of the crankshaft.
As the crankshaft rotates, zero degrees is the beginning of the firing order cycle. This is actually when ignition takes place on the last piston and is also equal to 720 degrees in the rotation cycle.
even fire:
In mid-1977 the 231 was converted to "even-fire" (120 degree spaced firing impulses) by changing the crankshaft, camshaft, distributor and (presumably for increased volumetric efficiency) the cylinder heads and intake manifold.
 Posted: Thu Sep 13, 2007 11:21 am |
andrewk: Thanks.
ROCKET: You're welcome.
 Posted: Thu Sep 13, 2007 12:17 pm |
91buickman wrote: what are you r trying to know because from the 2 links i posted and other reasearch is that they have diffrent firing impulses , and various engine parts ........ I will skip your giberish and move on to your, rude and unnecessary, cut and paste. 91buickman wrote: ........ by changing the crankshaft, camshaft ........ It does not tell us what changes were made. Without knowing the changes, we cannot know the difference. andrewk wrote: ........ In 1977, Buick introduced a new "split-pin crankshaft" in the 231. Using a crankpin that is 'split' and offset by 30° of rotation resulted in smooth, even firing every 120° ........ This one shows us the changes, and the difference, although, I question the use of the word "smooth". In addition, the camshaft lobes were repositioned to the new valve timing requirements. 91buickman wrote: ........ distributor ........ I do not believe it was changed, at that time. I will confirm, after I verify it. 91buickman wrote: ........ and (presumably for increased volumetric efficiency) the cylinder heads and intake manifold.
Presumably?
If a change was made, it was for a different purpose. I will verify when I check the validity of the distributor statement.
 Posted: Thu Sep 13, 2007 2:47 pm |
91buickman wrote: ........ So arent you the on ewho preaches ........ I follow the established protocol. You are still unable to act like an adult. 91buickman wrote: ........ The odd fire was fitted with the electronic disrubitor its last year in production ........ According to andrewk's post that would be '76. Use of HEI began in '73 CA, and '74 (or was it '76) 49 state, in all GM gas vehicles. If you are right, you were wrong when you said: 91buickman wrote: ........ by changing the crankshaft, camshaft, distributor ........ And, I was right when I made the correction. 88 Coupe wrote: ........ I do not believe it was changed, at that time. I will confirm, after I verify it ........ I will verify it anyway. 91buickman wrote: ........ also i have found that even fire is not exactly "true" in its meaning ........ If it is not, would it make your first post any less than BS? 91buickman wrote: ........ While the 90 deg. - V8 engine produces a natural even-fire engine with each cylinder firing at 120 deg intervals ......... Not true. They fire at 90° intervals, not 120°. I suggest you check your source(s) with a BS meter. 91buickman wrote: ........ the 90 deg. - V6 engine is an odd-fire engine ........ It is, but, as already stated, after '76, 90° V6 is even fire. 91buickman wrote: ........ Each pair of adjacent connecting rods shared a crankshaft throw with the two journals offset by 18 deg. This offset produced a firing sequence of 132 deg./108 deg. or a semi even-fire sequence throughout the firing order ........ Sounds familiar. Why am I thinking Chev V6? I will check it with my crank grinder, when he gets back from lunch. 91buickman wrote: ........ It also required that connecting rod lower ends be 0.050" narrower than the small block V8 engines to provide for a thrust bearing between adjacent connecting rod journals.
I still think you should verify your source(S).
I will compliment you on your ability to "Google" for answers that have already been posted. Does it involve using keywords culled from those answers?
