 Page 1 of 4 [ 50 posts ]  Go to page 1, 2, 3, 4  Next
 Post subject: Hard Starting-Delta 88
PostPosted: Wed Sep 12, 2007 9:40 pm
1988 Delta 88 Royale, 3800 series 1 V6, 334,505 miles.
For the last few weeks, the car has been hard to start. The problem isn't all of the time, sometimes the car will start fine all day, sometimes only the first time I start it, and sometimes every time. The engine cranks but wont turn over. Once the car starts it runs fine until the next time its shut off. I have noticed that if I turn the key to run (not start) for 5-10 seconds before trying to start the car it usually (though not all the time) starts the car up.
Help!
PostPosted: Wed Sep 12, 2007 10:09 pm
Witht that many miles on the car and other varibles that come along, Thes best thing to do is ensure your car has a tune up and other related items (electrical componets, starter,Ignition switch etc....) are in good working order, otherwise BTW you have a LN3 not a series one 3800, for future refrence. Hope this helps
PostPosted: Thu Sep 13, 2007 11:42 am
3800 Series 1, was optional for 1988, became standard equiptment for 1989.
The car is equipt with the Series 1 3800 V6, in fact its the only option the car was ordered with.
The car seems to have a hard time starting when its cold. This morning it wouldn't start, I took a different car to school, came back at 12 and it started right up twice.
Also I checked, I can hear the fuel pump run when I turn the key.
PostPosted: Thu Sep 13, 2007 12:53 pm
Have you been keeping your throttle body passages clean as well? thats also a factor of hard starts when cold. as for the engine code issue 91 is when the L27's cam out which are designated series 1 engines, Ln3's are designated pre-series 1's the big give away is your intake manifold if its one piece your a LN3 if its a 2 piece design your a l27
PostPosted: Thu Sep 13, 2007 3:20 pm
91buickman wrote:
........ BTW you have a LN3 not a series one 3800 ........
It doesn't get any better than this.
PostPosted: Thu Sep 13, 2007 4:07 pm
Absolutley pointless,waste of a post as ususal, True troll work here.
PostPosted: Thu Sep 13, 2007 5:39 pm
The irony is far too great with this one :lol: :lol: :lol:
PostPosted: Thu Sep 13, 2007 7:49 pm
The code is not an issue. This is what is called off-topic, and not applicable to the topic at hand. OP knows what he has, that's why he said what he did. The issue remains that it is hard to start. If the OP wanted to discuss the engine code, he would have made a thread for it. Any further continuation of this hijack will be deleted.
I couldn't agree more. But remember, he won't tolerate hypocrisy!
PostPosted: Thu Sep 13, 2007 8:17 pm
So... my car is still not starting as it should....maybe we could....I don't know....get back on topic.
An for the record the top of the engine says in big red numbers "3800".
PostPosted: Thu Sep 13, 2007 8:32 pm
Sorry 85cieraholiday,
This will help bring it back to topic-
Since it does run sometimes, we can infer that the engine has acceptable compression, and that the valves are sealing as they should.
What you will need to do, or have done, is figure out, empirically, what you are missing.
The next time it won't start, pull a spark plug, and see if it is wet. This will tell you if you have fuel or not. If you are getting fuel, but not spark, the plugs will just get wet, and you will be able to see this. I think you will find that you don't have fuel, since once it starts, it keeps going, which is uncharacteristic of a spark problem.
I would then go with a fuel delivery test, which seems most likely, as once it starts, it runs. Take off the fuel inlet and put it into a container, and have a friend cycle the key. It should pump a decent amount of fuel. A FSM would tell you what an acceptable volume is. If it is not pumping fuel well, or seems weak (that would require mechanical intuition or "feel", I think you will be able to tell if it is weak) then that would tell you there is a problem with either the fuel pump, fuel filter, or fuel lines leading up to the fuel rail.
If you have a good volume of fuel being delivered, and none to the engine, we then know the problem is further down the line, like with a pressure regulator, or a fuel rail, injector, etc, etc.
This is where I would start, if it were mine. Hope this helps you-
PostPosted: Thu Sep 13, 2007 8:49 pm
Sorry Frank, the Devil made me do it.
........ Take off the fuel inlet and put it into a container, and have a friend cycle the key ........
When diagnosing FI systems, pressure check is always more accurate than a flow test.
PostPosted: Thu Sep 13, 2007 9:05 pm
You're right- I was thinking in a minimalist sense, but a fuel pressure gauge should be easily obtainable, and it's worth doing the right way-
PostPosted: Thu Sep 13, 2007 10:46 pm
Thanks!
Saturday after work Ill be able to pull the plugs out and check, and if need be get working on the following steps. Ill keep you all posted of my progress.
PostPosted: Fri Sep 14, 2007 7:37 am
my car had that issue till i sent my fuel injectors in to be cleaned and flow matched, its a common problem with injectors that old to stick slightly before start up when cold. you also might want to try GM Fuel system treatment as well.
PostPosted: Fri Sep 14, 2007 7:26 pm
91buickman wrote:
my car had that issue till ........
Your history has nothing to do with the diagnosis of his problem.
To introduce that kind of thinking into the diagnostic process, is counterproductive.
Edit: Used the edit button for a quote. Took 3 edits to resolve it.
