It is currently Fri Nov 06, 2026 8:50 am
 Post subject: power window motor
PostPosted: Thu Sep 13, 2007 3:04 am
I have an '89 Delta 88 Royale, and the passenger side window won't go up/ goes up really damn slow. I think the window motor might be shittin out, because all my other electronic stuff works with no problems. So if I can't find an '89 Delta 88 Royale in the junk-yard to grab a window motor, what other Olds. models use the same motor?
 Post subject: Re: power window motor
PostPosted: Thu Sep 13, 2007 7:15 am
scroll down, you wouldnt believe how many cars use the same motor, so it shouldnt be a problem, although to be real if youre going to keep the car a long time id buy the motor new, or remanufactured at a cost of 55.99 and under IMO. anyway heres the link for the application list click on detailed apps at the bottom of the page.
http://www.cardone.com/English/club/mem ... TNUM=4219#
and this a price sheet from rockauto.com
best of luck
-marshall
A-1 CARDONE Part # 4219 {[Window Lift Motor] Reman.}
Front Left; Supplied w/Gear;Supplied w/o Regulator
Front Right; Supplied w/Gear;Supplied w/o Regulator
$23.89 $6.00 $29.89
ACI Part # 82458 {Power Window Motor}
Front Left
Front Right
$31.79 $0.00 $31.79
DORMAN Part # 742150
All Windows; Motor Only
$31.79 $0.00 $31.79
CARDONE SELECT Part # 82144
$33.79 $0.00 $33.79
A-1 CARDONE Part # 42102 {[Window Lift Motor] Reman.}
Rear Right; Supplied w/Gear;Supplied w/o Regulator
$31.79 $7.00 $38.79
A-1 CARDONE Part # 42103 {[Window Lift Motor] Reman.}
Rear Left; Supplied w/Gear;Supplied w/o Regulator
$31.79 $7.00 $38.79
ACI Part # 82568 {Power Window Motor}
Rear Left
$39.89 $0.00 $39.89
ACI Part # 82567 {Power Window Motor}
Rear Right
$49.79 $0.00 $49.79
CARDONE SELECT Part # 82102
$49.89 $0.00 $49.89
CARDONE SELECT Part # 82103
$49.89 $0.00 $49.89
ACDELCO Part # 12497971
MOTOR,FRT S/D WDO REG w/ELEC SI WDO(A31)
$106.79 $0.00 $106.79
ACDELCO Part # 22062568
MOTOR,RR S/D WDO REG LEFT HAND; 4 DOORS
$126.79 $0.00 $126.79
ACDELCO Part # 22062567
MOTOR,RR S/D WDO REG RIGHT HAND; 4 DOORS
* Non-stock item--shipping delayed up to 12 business days *
PostPosted: Thu Sep 13, 2007 1:01 pm
s0ad wrote:
........ because all my other electronic stuff works with no problems ........
Check for clean tight electrical connections, and that the ground is still solid. Then that the gears, tracks and linkage are not worn or binding. If you put power directly to the motor and the speed increases, the motor is not the problem.
This, this, or this, might be of help.
91buickman wrote:
scroll down ........ another rude and unnecessary, cut and paste ........ 12 business days * .......
