It is currently Fri Oct 23, 2026 10:34 am
 Page 1 of 1 [ 11 posts ]
 Post subject: Hard shift
PostPosted: Fri Oct 05, 2007 2:40 pm
When I shift into Drive or Reverse from Park, it goes into gear kind of harsh. I took it to the transmission shop and they told me It needed the engine mounts replaced. So I had that done, but it doesn't seem to have made a difference. Does anyone have any ideas? Is it possible the rough shift is just normal?
Thanks in advance,
Sean
 Post subject: Re: Hard shift
PostPosted: Fri Oct 05, 2007 4:35 pm
Does the car idle higher than normal? Is the transmission fluid clean, and is it full?
There are a few different causes for this symptom... Once we have a little more info, it will be easier to tell-
PostPosted: Fri Oct 05, 2007 5:11 pm
Thanks for the response. The transmission fluid is full and looks pretty clean. It could probably uses a change since it hasn't been done in a few years. But have only put about 15000km on the car in that time.
The idle does seem to be on the high side especially when cold. Could a high idle be the cause? How could I check the idle speed? I have looked for tachs in the past, but havent been able to find one. My timing light doesn't show rpm. Thanks.
PostPosted: Fri Oct 05, 2007 6:29 pm
DId they replace the engine and trans mounts? you just mentioned the engine mounts which still leaves the trans mounts suspect
PostPosted: Fri Oct 05, 2007 7:15 pm
91buickman wrote:
........ which still leaves the trans mounts suspect
Nothing to do with his problem.
A broken trans mount (there is only one) would exhibit different symptoms.
PostPosted: Fri Oct 05, 2007 7:41 pm
sean000 wrote:
........ transmission shop and they told me It needed the engine mounts replaced .........
Left mount? Possible cause. Unlikely, but possible, if the engine idle was very high, and the mount was broken.
Right mount? Not possible.
Did they return the old parts to you? Broken mounts would be in two pieces. If they are still serviceable, one piece.
If the problem is not in the trans, an improper tune up, is the probable cause.
Assuming your trans shop is competent, they will have eliminated the TV cable and modulator.
PostPosted: Fri Oct 05, 2007 11:22 pm
I was told the transmission mount was fine. I saw the broken left mount before they replaced it and they replaced the right one as well.
I'm having my doubts.
PostPosted: Sat Oct 06, 2007 12:42 am
sean000 wrote:
........ The idle does seem to be on the high side especially when cold ........
Fast idle is part of the choke system and should go away with a tap on the gas pedal. You could experience an abnormal shift while it is still engaged, but should not, at normal idle.
........ Could a high idle be the cause? ........
Could be part of it. It is normally checked, as part of a normal tune up.
........ havent been able to find one ........
If I was starting over, I would be looking at something like this.
sean000 wrote:
........ I saw the broken left mount before they replaced it and they replaced the right one as well ........
No problem yet.
Road test is usually performed after the repair. If it did not show any improvement, at that time, what was the explanation?
........ I'm having my doubts.
Nothing wrong with a second opinion, from another shop.
PostPosted: Sun Oct 07, 2007 7:43 pm
Okay, bought a tach yesterday and gave my carb a slight adjustment. After doing so, I noticed that the (cam follower???,little motor conected to a bolt that pushes against the throttle arm) was holding the idle higher than normal. So I adjusted that, and my car seems to be shifting smoothly again. Hopefully, that is the end of that...guess I got a needed engine mount replacement out of the whole thing.
Thanks for all your help!
Got another problem though...
PostPosted: Sun Oct 07, 2007 8:56 pm
sean0000 wrote:
Some times it shifts back down again right after it shifts(it also happens between first and second at times)
Your transmissions shifts are controlled by a vacuum modulator, that uses engine vacuum to give the transmission a pulse to shift. If this is not working correctly, the transmission may shift erratically, as you describe.
It could also be the TV cable, which controls the transmission "kicking down". This cable runs from the carb linkage down to the transmission.
I just realized that Norm already mentioned that both of these would have been eliminated by a competent shop- I would take the advice of getting a second opinion-
PostPosted: Mon Oct 08, 2007 6:17 am
Note my references to a "tuneup".
sean000 wrote:
........ I took it to the transmission shop and ........
Was that advise in another TOC thread? There was a similar thread recently, but I couldn't find it. Don't know if it was you, but if it was, there might be some helpful information in it.
You have two (if not three) other live threads going at this time. There is a good possibility they are all directly related to the following:
http://www.oldsconnection.com/forum/vie ... 2582#22582
We need to deal with the state of tune before proceeding here.
