 Page 1 of 1 [ 6 posts ]
 Post subject: won't start
PostPosted: Tue Oct 09, 2007 9:24 pm
I tried to start up my car this morning (an 02 Alero) and it turns over but will not start. I charged the battery and it made no difference. I think it might be the spark plugs or something with the computer. Any ideas?
 Post subject: Re: won't start
PostPosted: Tue Oct 09, 2007 9:27 pm
try swaping out your fuel pump relay with the a/c relay to see if the fuel relay is bad.
PostPosted: Tue Oct 09, 2007 10:12 pm
It could be many things- In order to narrow it down, you will need to perform a couple tests.
The first one I would do would be an ignition test, with a spark tester. If the car has spark, I would then go do a fuel pressure test, which will tell you if fuel is being delivered, and at what pressure it is being delivered at. Between the two tests, you will then know where to look.
You could start swapping parts, but I would go at this systematically-
Hope this helps-
PostPosted: Tue Oct 09, 2007 11:12 pm
Of cource you should go at this systematicly but GM cars 1997-2005 have huge problems blowing fuel pump relay's and resistors causing this same situation out of no where. Hell its free, quick and simple to see, not to mention at least eliminating from the list of possibilities...IMO
PostPosted: Wed Oct 10, 2007 5:10 pm
Thank you for the suggestions, this gives me a reference to look at.
PostPosted: Wed Oct 10, 2007 9:20 pm
My car runs fine now, I had a guy come over to take a look at it and apparently when the battery is dead the car won't start. I had to reset the security system and some other stuff but it's all godd now.
