 Page 1 of 1 [ 7 posts ]
 Post subject: 1986 Toronado - No Heat
PostPosted: Thu Oct 11, 2007 5:56 am
Just picked up a well-used '86 Toronado as a winter daily driver. It's got almost 190,000 miles and I think I'm the fifth owner, but she's in decent shape. The only real mechanical problem is that it's badly in need of some suspension work.
Anyway, my heating problem. The car was blowing nice warm air when I picked it up, and after I'd driven for an hour or so, it got too warm, so I turned down the temperature and it blew cool air. So far, so good.
Then, an hour or so later when night fell and it cooled off, I wanted some heat again, so I jacked the controls up to 75 or something.
...And there was no heat. Maxed out the temperature; no change. Set it to cold again, then warm. No change. Turned the whole unit off and back on; nothing. Pulled over, turned off the car, started it again; same story. Even tapping the side of the dash like an old TV didn't work.
Now from looking around forums like these I've read that people's electronic dashes have given out and none of the gauges (or the HVAC controls) work. My dash is working fine, and the previous owner had it rebuilt (think < 3 years ago). The dash lights sometimes don't turn on at night, but I'm going to check out that sensor in the defrost vent for that. I can still control everything just fine, but when I set it to be warm, it keeps blowing cold air.
I have a proper service manual coming in the mail, but I got impatient and found out through the Internet plus trial & error how to run the diagnostics through the climate control unit, as any 4th-gen Toronado and some Cadillac model owners might know about. I got three codes for the BCM which either are, or could be, relevant:
B337 - Loss of HVAC Programmer Data (Cleared, never came back)
B440 - Air Mix Valve (Door) Circuit Problem (Current)
B552 - Keep Alive Memory Error (Cleared, Never came back)
Any inputs? Suggestions? My original feeling that the heat blend door/valve itself had gotten stuck seems close, but somehow I think that's not really it. Looks to me that either the mechanism that moves that blender door, or the HVAC programmer unit, are the culprit(s). Agreements? Disagreements? Any 4th-gen Toro experts out there?
PostPosted: Thu Oct 11, 2007 6:37 am
Welcome to TOC
Have you checked the coolant level?
PostPosted: Thu Oct 11, 2007 7:20 pm
I doubt it will be a coolant issue, with that air mix door code popping up.
Could there be something in the way of the door, that fell down when you initially turned the heat off? It could be stopping the motor from moving the door, finally giving up and creating an error code... Fuses look ok?
PostPosted: Fri Oct 12, 2007 8:10 am
I just didn't want him to go through alot of trouble then realize... oops the radiator is almost empty
been there, done that #-o
PostPosted: Fri Oct 12, 2007 8:47 pm
73Delta88 wrote:
.... been there, done that #-o
I know what you mean... Done it myself many a-time... Its a good indication to pull over and find some water!!! :-)
PostPosted: Wed Oct 17, 2007 6:00 am
Hey, thanks guys. Sorry I skipped out for a while.
Right after I picked this car up last month, I had to drive it a few hundred miles so the first thing I did was check the fluids, etc.
I can't say it's impossible, but I'm not familiar enough with how the air ducts are shaped and such to tell you how probable that is. I checked all my fuses and replaced the dead ones soon after getting the car. Unfortunately the only dead ones were for the trunk pulldown and the remote fuel door release, so that easy fix was ruled out.
To make matters more interesting, I've driven it a few times in the last week, and magically one day when I started it up, I could've sworn there was warm air blowing on me after a few minutes. Sure enough, the heat's back (I've switched it on and off, warm to cold a bunch of times and it works 100%), but who knows for how long? Now I'm starting to think it's a loose connection somewhere. Someone on another forum thinks it could still be the HVAC programmer, too.
His comment was that these systems were problematic from Day 1. Being a piece of GM electronics from the 80's, I don't doubt him for a second.
PostPosted: Sat Oct 27, 2007 3:32 pm
Images: 11
hi 86toronado,
not the same problem but we very had similar one last year.... it might be helpful to look this topic http://www.oldsconnection.com/forum/viewtopic.php?p=15698#15698
and the problem was the AC blower\heator motor resistor.... the resistor chip is different on these electronic AC systems... in the stock resistor, the resistor chip seems more vulnurable to heat and other contidions .. the replacement part from the gm is more protecting the resistor chip... so resistor chip in these systems can easily malfunction from outside effects like heat and cold...so our AC controls behave very erraticaly when the stock resistor was living its last days...at least ours was totally weared because of that... hope it might help you in your problem but your problem seemed like to me the ac blower resistor!
by the way we were not getting any codes from system like you when this malfunction occured... so my advice is just a suggestion.... but our electronic AC s do these erratic things alot so i think i get used to it :) you know except these electronic failuries our cars are really mechanically reliable and have decent ride quality...so this is the thing which prevents me to get crazy because of that old era electronics.
