PostPosted: Tue Oct 16, 2007 11:16 am
Images: 8
Two weeks ago, my battery was completely drained after coming home from work. The battery was about 6 years old and I figured it was about time for a new one. Just to be on the safe side, I went ahead and had a new alternator installed. The old one wasn't spinning freely and you could hear a small rubbing noise coming from inside the housing. I checked all the cables at the same time making sure they were clean and everything was tightly connected. Problem solved, right? Wrong...
This past Sunday as I was getting ready to do some grocery shopping, the battery completely drained again. Bummer!
Yesterday, I went ahead and swapped another battery. And this time I put a load tester against the alternator and it was charging strong. So that elminated the possibility that I had a defective alternator.
The next step, was to test it for any shorts or grounds. While the car was off, I separated the negative battery lead and bridged a 12V test light between the battery and the terminal and started pulling fuses. It turns out that a relay switch that is connected to my seat belt inside my door panel was the culprit. I felt so dumb, because all this time, the "fasten seat belt" light would never extinguish after I would fasten my seat belt. And every once in a while I would hear this clicking noise coming from my driver's side door panel.
Well, I installed a new relay switch and the problem went away. But I never realized such a small thing like that could cause a battery to completely drain. Amazing!
PostPosted: Tue Oct 16, 2007 3:19 pm
good find. May seem like a simple problem, but those are always the worst to solve. Never heard of that one before!
