TheLSS
 Posted: Wed Nov 28, 2007 3:45 pm |
Joined: Wed Jan 10, 2007 10:51 am Posts: 30 Images: 6 Location: Canada
I had a somewhat similar problem with my car before the snow hit here. It's very possible that your passenger temperature actuator has failed. I can't explain why it works fine when there is a passenger in the vehicle, as there is no sensor in the seat, except possibly for the Airbag system(the electrical systems changed a lot from 1994 to 1995, due to OBD2, so I am unsure about the sensor, my car, however does not have a seat sensor), and that is not used for climate control decisions. The actuator is somewhat accessible, you can see it if you remove the glove box. It is on top of the heater ducting, on your right if you are facing the front of the vehicle. Take a look at it when you change the temperature from hot to cold and see if it moves. The position sensor was messed in mine so it just kept going back and forth, yours might not move at all. Normally it will move the passenger blend door from hot, stop, then you command the temperature to be cold, and it will move to full cold position and stop. The temporary solution if your actuator is not working properly is to unplug it, run the vehicle on full fan speed, and move the unplugged actuator until you get full heat on the passenger side, then leave it there for the winter until you can get a working replacement in there.
_________________ 1995 Burgundy Oldsmobile 88 LSS
Track Beaten, Off Roaded, and enough clarion equipment to rattle the hell outta any passengers!
73Delta88
 Posted: Wed Nov 28, 2007 7:15 pm |
TheLSS wrote: I can't explain why it works fine when there is a passenger in the vehicle, as there is no sensor in the seat,
Are you sure? we had a 1993 Regency 98 and I seem to remember something tricky about the dual zone heater, like a sensor in the seat... not 100% sure on that though.
 Posted: Fri Dec 07, 2007 8:24 pm |
afrats wrote: ...It is so nice having heat again.
Never notice it untill its not there
 Posted: Sun Dec 23, 2007 1:19 pm |
myfathersoldsmobile wrote: .... I even found a double cassette that had dropped down in, probably from the original owner.....
What tape???
myfathersoldsmobile
 Posted: Sun Dec 23, 2007 2:35 pm |
88delta88 wrote: myfathersoldsmobile wrote: .... I even found a double cassette that had dropped down in, probably from the original owner..... What tape???
An audio book read by Ed Asner, Murder at Kennedy Center
Puts the "Old" in Oldsmobile
I was ready to chuck it but my son saved it from the trash.
