 Post subject: more heater problems
PostPosted: Thu Jan 03, 2008 9:27 pm
i have a 94 olds 88 royal , heater blows cold air out of passenger side, here's how it goes.start car it blows hot air out both sides for about 30seconds then temperature reading starts flashing, then it starts blowing cold air out both sides. once temp stops flashing (after about 30 sec) it blows hot air out driver side only. i have changed the in dash climate control unit ,still same problem.then i changed the heat and a/c control module located on right side firewall beside glove box(this plugs into actuator which i disconnected) and still same problem. there has to be a temperature sensor somewhere sending the wrong signal or something. i diconnected the damper behind govebox just to have heat on pass side. my side still blows cold air untill temp reading stops flashing. i think it started after my battery went dead and i recharged it without disconnecting battery on a 10amp charge. i tried disconnecting battery, letting it drain slowly, to try and reset something but still have same problem. anyone have any ideas ??? the actuator behind glovebox does move, seem to do whatever it wants, i think it's getting the wrong signal from somewhere but where. that is the question?? could it be the temp control dial on pass side door, never changed that yet but i cleaned and it looked fine.
 Post subject: Re: more heater problems
PostPosted: Tue Jan 08, 2008 5:06 am
I'm had the same exact trouble in mine since I bought it. (94 olds 98, regency elite) Still no idea what the original cause was
I'm going to have to take it in for other heat related problems. If somehow the dual-zone climate control happens to be fixed in the process, I'll make sure to let you know what the problem was.
(In my case, heat worked fine for three years without bothering to fix the passenger side climate control. Within the last month, blower motor is constant-on, and most of the time the heat is non-functional)
PostPosted: Tue Jan 08, 2008 10:55 am
thanks for the reply twit. i still say there has to be a temp sensor sending the wrong signal. if someone would know where they were it would help,because i don't. sorry i can't help about your blower problem. i see your from wisc i'm sure it gets pretty cold down there too. you need all the heat you can get. lol
