 Posted: Sat Jan 12, 2008 12:10 am |
91parkave wrote:
Looks very clean in there...
 Posted: Sat Jan 12, 2008 12:26 am |
88delta88 wrote: 91parkave wrote: Looks very clean in there...
the benefits of living in the south...
strokercutlass
 Posted: Tue Jan 15, 2008 7:10 pm |
| TOC Mechanic |
The traction control will disable for a number of reasons on these cars....is there a check engine light coming on? Oxygen sensor codes will often disable the TCS to prevent engine damage from occuring......the audio control problem sounds like it could possibly be a bad clockspring in the steering column....
myfathersoldsmobile
 Posted: Mon Jan 21, 2008 10:49 am |
strokercutlass wrote: The traction control will disable for a number of reasons on these cars....is there a check engine light coming on? Oxygen sensor codes will often disable the TCS to prevent engine damage from occuring......the audio control problem sounds like it could possibly be a bad clockspring in the steering column....
Thanks for the reponse. I have no check engine light anymore, though I had codes earlier this year and replaced the ICM and upper o2 sensor, which cured the symtoms and the codes.
The strange thing about the TC is that it starts as enabled, then shuts off exactly when the tranny shifts into third.
I think I will simply disable the voulume control on the steering wheel to solve that other problem.
myfathersoldsmobile
 Posted: Fri Feb 01, 2008 10:52 am |
After replacing the bad stabilizer bushing, I still have a rattle in the front end every time I hit a bump or drive over rough road.
I went in for a State Inspection yesterday figuring they would tell me I have a bad ball joint. I passed. This morning I jacked the car up to check the front end and the ball joints were good, the tires didn't give at all in any direction. The ball joint boots were good. Similarly, I checked for tie-rod play and couldn't find any problems, all boots were intact there, too.
When I discovered the bad stabilizer bushing I only did one side, the side that was obviously bad. I do have a bushing assembly for the other side so my next step will be to put that on. Maybe there is play in the other bushing that only happens under load, and isn't seen when the car is jacked up.
91parkave wrote: glad you got the problem fixed i had the same thing happen to me, i replaced my end links with the polyurethane units from autozone slightly stronger but more durable, also while your under there make sure everything else is tourqued down i also had the bolts on the sway bar bushing start to come loose at the same time.
When you say "everything else" what should I be tightening?
Thanks, Jon
 Posted: Fri Feb 01, 2008 1:36 pm |
Is it just a singular pop, or is it like something is loose, and it rattles more than once.
You should also check the control arm bushings.
myfathersoldsmobile
 Posted: Fri Feb 01, 2008 5:01 pm |
andrewk wrote: Is it just a singular pop, or is it like something is loose, and it rattles more than once.
It seems like something is loose and rattles more than once.
I tried to get a look at the control arm bushings when I was under there and I saw a few cracks, but nothing I thought would cause play. I could be mistaken, though.
 Posted: Fri Feb 01, 2008 9:10 pm |
Is the rattle metallic sounding, or just a rattle? I'm sorry to ask so many questions, but it should help-
I'd look to anything that could bounce around more than once. Chances are suspension components are going to pop once or twice, whereas things like air dams, inner fenders, and strut debris shields could rattle around a lot more than that-
 Posted: Sat Feb 02, 2008 5:58 am |
myfathersoldsmobile wrote: ........ and I saw a few cracks, but ........
 Posted: Sat Feb 02, 2008 12:00 pm |
91parkave wrote: ....spray some wd-40 or heavy duty lube of your choice heavily....
WD-40 is not a heavy duty lube.
