PostPosted: Sun Jan 06, 2008 11:05 am
About a month ago I started getting a clunk sound from the steering column of my 2001 Aurora. The clunk was then joined by a squeak every time I hit a bump. I also began to notice there was some play in the wheel that was getting worse and worse. After doing some research online, I found that these are symptoms of a worn/damaged intermediate steering column, and that this is a very common problem on FWD G bodys (Aurora/Bonneville/LeSabre) as well as the Cadillac Seville.
A trip to the local dealership Buick Pontiac GMC of Milford [url=buickgmcofmilford.com]Buick Pontiac GMC of Milford[/url] found that my research had pointed my in the right direction. I'm very pleased with the service I got and would send anyone to them for service. Hopefully other Aurora owners with find this useful should they find similar symptoms with their car.
PostPosted: Sun Jan 06, 2008 6:07 pm
Very common with the Intrigue too...
Did they just regrease it? Part Number 26098237 - Steering Column Shaft Lube Kit
The TSB says NOT to replace the intermediate shaft, and instead, just regrease it. I'm guessing that's what they did.
Affected Model(s):
2001-2004 Buick Regal
2005-2006 Buick Allure (Canada Only) LaCrosse
1997-2005 Chevrolet Cavalier
2000-2006 Chevrolet Impala, Monte Carlo
1998-2002 Oldsmobile Intrigue
1997-2005 Pontiac Sunfire
2004-2006 Pontiac Grand Prix
Supercedes:
This bulletin is being revised to remove the Cadillac Seville, Oldsmobile Aurora and Pontiac Bonneville models.
PostPosted: Sun Jan 06, 2008 10:51 pm
Mine was replaced due to "excessive wear". I had read up on the lubrication issue, but was told mine was beyond that. In all honesty it seemed really bad as the steering had a very loud clunk in it every time I turned the wheel as well as the play in the wheel getting worse. I had read on an Aurora forum that its very common, and many of them had also had to replace the shaft.
