 Posted: Sun Feb 17, 2008 3:56 pm |
Code 26 is "quad driver module" which is a fancy name for a series of 4 on/off switches that are monitored by the ECM.
This means that one of the switches the ECM is monitoring is not producing an expected value. This could be because one of the 4 switches is bad, or because the ECM is bad. Is code 26 the only code that comes up in the cycle, or are there others?
If you are not mechanically inclined, or don't have a solid understanding about how electrical systems work, I would take it to a qualified shop. Otherwise you will need a factory service manual (FSM) so that you can follow the recommended testing procedure, and a good Multimeter to test the circuits.
I am away from home now, or I could probably be a little more help-
 Posted: Mon Feb 18, 2008 10:35 am |
Glad I could help. Let us know how it turns out.
 Posted: Sun Jun 08, 2008 2:25 pm |
If the contacts were the problem, the ECM would not store a code related to the quad driver.
In diagnosing a problem, especially over the internet, it is best to figure out the problem first, and then try to fix the issue systematically, instead of just trying random things, and hope it works. Since there are so many different possibilities, there is no one "magic" fix.
Welcome to TOC,
