GraveReaper0 wrote:
Man its cold in Chicago ........
High today here, was 63° and it is 52° now. Cooler than normal for this time of year.
GraveReaper0 wrote:
........too weak for what I believe it should be ........
What is your belief based on?
GraveReaper0 wrote:
........ but is that all its got? ........
Very likely. Check the power and ground connections. You know the drill.
GraveReaper0 wrote:
........ Is there a stronger blower motor I can get ........
A "direct bolt in"? Not likely. Probably easier to have it rewired by a motor specialist. If it is, in reality, weaker than it should be, OEM quality replacements are available everywhere.
GraveReaper0 wrote:
........ or is there something I can do to get it to blow harder? ........
This looks like an easy solution, but its unwanted side effect would be to be to raise your cabin temperature at the same time.
