 Page 1 of 1 [ 13 posts ]
PostPosted: Thu Mar 13, 2008 9:28 pm
i have this big problem with my altenator. i have a deck and amp in my car and since i put those in every time i turn on the amp or have the deck on loud the car will squeel. not it does it all the time. i replaced the alternator. i dont know what to do
PostPosted: Fri Mar 14, 2008 8:54 am
Electrical loads will not make the alternator squeal. You either need to replace the alternator belt, or re-tension the alternator belt. Depending on how long ago you replaced the alternator, if you had the belt on too tight, a bearing could have failed in the alternator. To check this, loosen the belt, and remove it from the alternator pulley. Spin the alternator with your hand. If it rotates freely and quietly, it is probably ok.
I'd bet 10 to 1 it's the belt.
PostPosted: Sat Mar 15, 2008 8:46 am
i replaced the belt and alternator like a month ago didnt help at all. belt tension is fine. the belt seemed really loose to me so i tightened it up a bit. that didnt seem to help much. i might just have this mechanic i know look at it, see what he says about the whole situation. electric draw wont make it make noise. i didnt know it. so that means my amp and deck has nothing to do with the noise. oh and when i turn the fan on all the way in the car, something will squel. and thats just crusin when it normally doesnt make noise. im not 100% sure it is the alternator. im just assuming
PostPosted: Sat Mar 15, 2008 12:26 pm
is the belt dry? have you checked the alignment of the belt to make sure the pullies are in line?
PostPosted: Sat Mar 15, 2008 12:34 pm
Have you checked your other belts?
PostPosted: Sat Mar 15, 2008 12:35 pm
i soaped the belt, it wasnt dry before because of there was coolant spraying everywhere in the engine because of the intake manifold gasket was leaking...bad. i have not checked if the pullies are in line. how would i do that besides eyeing it up. i didnt know you could adjust that.
PostPosted: Sat Mar 15, 2008 12:38 pm
Soap as in like a bar of soap?
PostPosted: Sat Mar 15, 2008 9:59 pm
yeah bar soap. i havent checked the other belts, i dont know what i would be checking for. they all are there and seem tight enough.
PostPosted: Sun Mar 16, 2008 12:17 am
using a straight edge but thats the last thing to check right now, did you replace the belts after the coolant leak? and a bar of soap if anything is probably doing it more harm then good in your case, i use some steel wool or scotch brite on the pulley and very light rub on the belt when i had coolant leak, hopefully it might work for you to.
PostPosted: Sun Mar 16, 2008 8:30 am
i replaced the belt during the leak. i put 200 miles on the car since is got fixed. what would the steel wool do?
PostPosted: Sun Mar 16, 2008 10:25 am
The steel wool would remove any glaze and/or dirt and/or rust on the pulley that may be allowing the belt to slip.
Your belts should be installed dry, and that is the way they were designed to run. Belt dressing and other products that are intended to help a belt attain more ¨bite¨ are band-aid fixes for a new belt.
At any rate, you will want to check your other belts, as if you had coolant spraying everywhere, there is a good chance the other belts got soaked too.
PostPosted: Sun Mar 16, 2008 1:01 pm
^^what he said, also what amperage is the alternator you bought? are you running your system with a capacitor? did you upgrade the factory alternator wire to anything bigger?
PostPosted: Sun Mar 16, 2008 6:33 pm
ummm im not 100% sure on the amperage. what ever autozone had. i do have a cap. i thought that would help. well the battery wasnt charging because that wire going from the alternator to the battery was bad. so i took a wire from a amp wire kit and rewired that.
