 Post subject: AC low pressure cut-off
PostPosted: Sun Apr 20, 2008 9:05 am
Where is the low pressure cut-out switch for the a/c on a 1997 olds 88?
PostPosted: Sun Apr 20, 2008 4:31 pm
Refrigerant Pressure Sensor / Switch: Description and Operation
An electronic A/C pressure transducer is mounted on the discharge line of the A/C compressor suction/discharge hose assembly. Its output to the PCM is
variable and is dependent upon pressure inside the line. A higher pressure results in a higher voltage output. A/C pressure is constantly monitored to:
* Disengage the A/C clutch if the pressures are high -2700 kPa (430 psi).
* Disengage the A/C clutch if pressures are too low -below 303 kPa (44 psi).
* Control cooling fan operation of low and high speed.
