 Posted: Wed Apr 23, 2008 12:37 pm |
IIRC, your car has two flasher units, one for the hazards, one for the turn signals. the flasher units are located in the fuse box, and they are bigger than the fuses.
You may have a bad flasher- To test, try switching the two flasher units out for each other, and see if the signals work, but not the hazards. If that happens, replace the bad flasher.
 Posted: Thu Apr 24, 2008 9:34 am |
4 way flasher switches two sets of turn signals, at the same time, at the same cadence.
If the flashers are reversed, the turn signals should cycle slower and the 4 ways, faster.
2ROCKETS73 wrote: ........ I don't want to make matters worse by plugging in a wrong part.
Not possible.
