 Page 1 of 1 [ 12 posts ]
PostPosted: Tue May 06, 2008 10:47 pm
Hi, could anyone point me in the right direction? I have a 2000 Bravada. While driving, [and this is intermittent] when the heater is on; usually above 70F, the water temperature gauge creeps to 260+ and check engine light comes on. If I turn the heater to cold, the temperature gauge goes back to normal. I checked and have all fluids and coolants at correct working levels.
Does this sound like my thermostat is bad? :(
PostPosted: Wed May 07, 2008 3:35 am
When you have the heater on, does it blow cold air...or is it warm?
PostPosted: Wed May 07, 2008 8:32 am
It alternates between blowing cold air and hot air . The overheat condition comes on when the heater blows hot air in the car. As soon as it overheats, I turn the heater to cold and the gauge drops back to 120.
PostPosted: Wed May 07, 2008 7:09 pm
120 on your temp gauge is some kind of malfunction, if youre at full operating temp, you should be sitting around 200 degress + or -, but not 120, have you had the cooling system flushed yet? Dex-cool can cause some serious problems if not properly maintained, I would recomend you take care of your thermostat, and have your whole cooling system flushed.
PostPosted: Wed May 07, 2008 7:35 pm
You're right, that was a mis-type. It's 210 not 120. I am planning on flushing the radiator and change the thermostat this week-end. We'll see if that fixes the problems. :blush:
PostPosted: Wed May 07, 2008 7:59 pm
Hi atomium58,
........ and this is intermittent ........
This tells us, it's a communication issue.
........ Does this sound like my thermostat is bad? ........
Does not sound like it is overheating. That means, it has nothing to do with cooling system, which, includes the thermostat.
........ I turn the heater to cold and the gauge drops back to 120.
Coolant temps do not rise and fall instantly.
Look for an electrical (short or open circuit) connection, between the temp sender and the gauge.
PostPosted: Wed May 07, 2008 8:06 pm
Besides what 88 coupe mentioned,do you notice a check engine light on during this problem?
PostPosted: Wed May 07, 2008 8:53 pm
More bogus advice from our resident BS artist, who seems "gets off" by telling people to waste their money.
91buickman wrote:
........ have you had the cooling system flushed yet? ........
The cooling system is not the problem.
Try to keep up with the rest of us.
91buickman wrote:
........ Dex-cool can cause ........
No different than any other antifreeze/ coolant.
91buickman wrote:
........ some serious problems ........
Yes. Cooling system problems. But, he did not describe a cooling problem.
Read what is there, not what you think is there.
91buickman wrote:
........ if not properly maintained .......
By definition, improper maintenance, can cause problems.
91buickman wrote:
........ I would recomend you take care of your thermostat ........
Landfills are full of perfectly good thermostats, because of advice from "clueless" BS artists.
91buickman wrote:
........ and have your whole cooling system flushed.
A cooling system "flush" is not the solution to a cooling problem. It is, simply, part of a normal coolant replacement, during the normal maintenance cycle.
PostPosted: Wed May 07, 2008 9:00 pm
91buickman wrote:
........ do you notice a check engine light on during this problem?
Already covered, in the opening post. Here it is. again:
atomium58 wrote:
........ and check engine light comes on ........
PostPosted: Wed May 07, 2008 10:02 pm
Yes norm you are correct, I stand corrected
PostPosted: Wed May 07, 2008 10:12 pm
either way it goes cooling system maintence is key and solid advice to anyone who wants to keep their car maintained especially with Dex cool.
PostPosted: Fri May 09, 2008 12:23 am
91buickman wrote:
........ solid advice to anyone who wants to keep their car maintained ........
And like oil, trans, brake fluid, and air filer changes, it has nothing to do with this topic.
Nothing to do with this topic = Just more childish BS.
