 Post subject: still stalling out
PostPosted: Wed May 28, 2008 11:14 pm
i replaced icm and maf sensor and thought car was fixed but the weather warmed up and now my car is stalling on me again.once its warmed up it sputters, coughs and eventuallly stalls, even while driving around city and not just at highway speeds. i just have to shut it off for like 10 seconds then it fires right back up. found a cracked vacum line comeing from fuel pressue regulator and fixed that but it still stalls. you guys got any other ideas what i should check. fuel pressure?? fuel pump?? also another question what exactly does that charcoal filter in the right front of the engine compartment do, cause every once in a while i can here that solinoid clicking away like crazy?? any help would be appreciated got a 94 olds 88 with 3.8 litr
 Post subject: Re: still stalling out
PostPosted: Thu May 29, 2008 4:42 pm
also have another question what kind of fuel pressure should i be getting, tested it today and we got 32lbs of pressure with just the key on and also when motor running. when we applied full throtle it went up to about 42 lbs then back to 32 whenwe released the gas. is this fuel pressure high enough and if its not would it be the cause of my stalling out
PostPosted: Fri Jun 06, 2008 2:03 pm
I had a similar type problem on my 1998 eighty eight. I cleaned the electrical contacts on my key with a pencil eraser and it's never happened again. Don't know if your key has the embedded electronics or not.
Phil
PostPosted: Sun Jun 08, 2008 5:38 pm
obiwann wrote:
........ what exactly does that charcoal filter in the right front of the engine compartment do ........
Evaporative emissions cannister. Part of the gas tank vent system. It catches gas vapors and sends them to the combustion chamber to be burnt.
Not part of your problem. Change the filter, and call it good.
PostPosted: Wed Jun 11, 2008 5:52 am
http://www.oldsconnection.com/forum/vie ... 4281#24281
