Hi Sabertooth,
........ because of the gaskets, i know, im going to replace them ........
Trunk lid uses a gasket,
available here, rear glass does not.
When you get the trim off, check for rust along the bottom of the glass. Leaks, due to rust, are common in '60s/'70 A bodies.
........ if theres a way i can remove the rust thats accumulated ........
POR-15. I've used it. It works.
If it's more than "surface rust"
OPGi sells patch panels.
........ to my knowledge the air vents on the driver and passenger sides ahead of the doors. How do i fix this? ........
Anything can be fixed.
First, you need to find the exact location of the leak(s).
