 Page 1 of 1 [ 1 post ]
 Post subject: water pump issues
PostPosted: Fri Aug 08, 2008 11:13 pm
my olds has sat for a long time and went to drive it and it had no coolant i remebered changing the water pump a while back and figured i never filled the coolant back up. When i poured it in it started leaking near the bottom right area of the water pump. Now my question is on the olds cutlass ciera 3.3 v6 is there supposed to be 2 pins that sick out of the block for the water pump or just one on the far left cause there isnt any threads in the hole so a screw cant go there and there is a hole in the pump housing but i cant seem to figure out what went there so i can stop the leak.
