 Posted: Thu Aug 21, 2008 10:00 am |
85cieraholiday wrote: ........ did the same thing to my other cars and found they didn't do this ........ Are any of them front drives and the same vintage? 85cieraholiday wrote: ........ top of the engine that moves when I push on the car. Is this a bad motor mount? ........
It's supposed to move enough to notice. How much, is better left to to someone who knows more about that era.
 Posted: Sun Aug 24, 2008 11:22 am |
Is the rest of your "fleet" '88 or newer?
Up to about '88, "loose" mounts were used to "band-aid" the inherent "balance problems" in 4 and V6 engines. They were no linger needed when they started using, the more expensive, balance shafts.
In the absence of any other evidence, my guess is, they are doing what they were designed to do.
 Posted: Tue Sep 23, 2008 3:12 am |
raskull wrote: ........ I dont know how to or have any equipment to fix it ........
Here is the answer to the first part. It will tell you what you will need, for the second.
91parkave
 Posted: Wed Sep 24, 2008 4:38 pm |
raskull wrote: im having similar issues right now with my 93 eighty-eight. the lower transmission mount is absolutely shot. when the car is in gear and i give it gas, the engine is twisting out of the compartment so much that its leaving in imprint on the hood insulation. When i brought it to the garage, the guy told me the bracket is about 30 bucks, but it would be about 250 in labor. I dont know how to or have any equipment to fix it but i need to do something about it soon. its like that penzoil commercial where the engine leaps out of the car.
Jack, wooden block, long pry bar, 13 or15mm socket with swivel end helps, breaker bar. I only paid 50 in labor when i dint know how to do it, so i would shop around if i were u
 Posted: Wed Sep 24, 2008 10:03 pm |
91buickman wrote: Jack, wooden block, long pry bar, 13 or15mm socket with swivel end helps, breaker bar ........
Yes.
And we can see what a fine job you did.
 Posted: Thu Sep 25, 2008 10:02 am |
Not at all.
The images are actual examples your "professional" work, are relevant to this topic, and were an appropriate response to your childish post.
I you would like to discuss it further, you can PM me, or you can start a new thread in the proper forum.
 Posted: Fri Sep 26, 2008 4:57 pm |
85cieraholiday wrote: ........ The car is back together and running well.
Thanks for the update.
