 Page 1 of 1 [ 7 posts ]
 Post subject: Transmission Overfill
PostPosted: Thu Oct 30, 2008 12:55 pm
I checked my tranny fluid level and it is about an inch above the full mark. Could that cause me to get a check engine light? I am curious because it has come on since I have had the car but it drives nice except for the power pulsation under light throttle inputs.
Is there a way to remove some of the tranny fluid without dropping the pan?
Thanks
Thad
PostPosted: Thu Oct 30, 2008 3:08 pm
Yes, you can siphon it out....how you do it depends on if your willing to buy a mity-vac or if you've mastered the technique of not getting trans fluid in your mouth, your call. :D
PostPosted: Thu Oct 30, 2008 6:17 pm
Do you think this could cause a pulsation in power with a light throttle input?
PostPosted: Fri Oct 31, 2008 8:24 pm
You might use a cheap turkey baster as well. Just don't re-use the turkey baster. You can add some fuel line to the end of the turkey baster in order to extend its reach.
PostPosted: Sun Jan 18, 2009 5:27 pm
My fluid is low and i have this problem sometimes. Like when im on the highway going 50 with a little bit of engine load and part throttle ill get a little pulsation.
PostPosted: Tue Jan 27, 2009 12:46 am
VW GUY wrote:
[My fluid is low and i have this problem sometimes.
Add some? ;) had to know that was coming...
PostPosted: Wed Feb 25, 2009 8:03 pm
I had the Dealer replace the rear main seal and a handful of other gaskets and now it runs like a top.
Now I just need to get my engine to not overheat and the AC needs to work....
Thad
