 Page 1 of 1 [ 14 posts ]
PostPosted: Sun Jan 04, 2009 3:01 pm
I'd like to attempt to change the O2 sensor on my 94' 88 Royale. Any hints/tips? Where is it located? How hard would it be? Cost?
The thing is using too much gas, and has never been replaced (150k miles). About 375 miles for 18 gallons, sometimes only 340-350 miles.
I've changed water pumps, brake pads/rotors, alternators, plugs and wires...So I know a little about car maintenance.
TIA for any and all help.
nothing
PostPosted: Mon Jan 05, 2009 12:49 am
Hi vtruss8,
........ Where is it located? ........
In the exhaust manifold, on the firewall side of the engine.
........ The thing is using too much gas, and has never been replaced .......
O2 sensor does not use gas. Other than that, how does the car run?
........ About 375 miles for 18 gallons, sometimes only 340-350 miles ........
Vs what, during the summer?
The "oxygenated" additives, used during winter months, displace some of the energy in a volume of gasoline, at the pump. Less energy = less MPG.
PostPosted: Mon Jan 05, 2009 7:01 am
Thanks for the reply!
I could have made it a bit more clear, but doesn't a bad O2 sensor cause bad gas mileage?
I've only had the car a few months, but 350 miles per 18 gallons seems a bit low to me. Seems like I should be getting around 400-430 per tank.
Car runs pretty good other than that though.
Thanks much!
nothing
PostPosted: Tue Jan 06, 2009 3:17 am
vtruss8 wrote:
........ doesn't a bad O2 sensor cause bad gas mileage? ........
It doesn't cause anything. It simply monitors the amount of O2 in the exhaust, and passes the information to the computer. Computer uses the data to make fuel/air mixture corrections, as needed. If the mixture is too rich, or too lean, it will cause other symptoms, in addition to excessive fuel use.
vtruss8 wrote:
........ 350 miles per 18 gallons seems a bit low to me ........
In comparison to what?
vtruss8 wrote:
........ runs pretty good other than that though.
Sounds like your O2 sensor is doing what it is supposed to do.
Start with the basics: Check your tire pressures and your air filter.
PostPosted: Tue Jan 06, 2009 7:31 am
Maybe I'm thinking Oxygen sensor then. Because I know one of the two regulates the air to fuel ratio injected by the fuel injectors, and a bad one can cause bad gas mileage (injecting too much gas). Is this a myth?
nothing
PostPosted: Tue Jan 06, 2009 11:56 am
Sensor failures
Normally, the lifetime of an unheated sensor is about 30,000 to 50,000 miles. Heated sensor lifetime is typically 100,000 miles. Failure of an unheated sensor is usually caused by the buildup of soot on the ceramic element, which lengthens its response time and may cause total loss of ability to sense oxygen. For heated sensors, normal deposits are burned off during operation and failure occurs due to catalyst depletion, similar to the reason a battery stops producing current. The probe then tends to report lean mixture, the ECU enriches the mixture, the exhaust gets rich with carbon monoxide and hydrocarbons, and the mileage worsens.
From Wikipedia. So, I guess a bad O2 sensor would cause worse gas mileage, and would be worth replacing if the gas mileage I'm getting is not what I think it should be (ruling out other possible problems).
Not to argue with ya 88 Coupe, but a bad O2 sensor can indeed cause bad gas mileage, due to the fact that it can send signals to the computer to enrich the fuel mixture unneccessarily.
nothing
PostPosted: Tue Jan 06, 2009 11:31 pm
It is your car, and your money.
PostPosted: Tue Jan 06, 2009 11:43 pm
I can get a Bosch Oxygen Sensor Four Wire, Heated for about $30 new. It's good knowing someone who works at Advance Auto...hehe
I'll do a few runs and get an average mpg before install, and then a few under similar conditions after I put in the new one and see if it was worth it.
You could very well be right, could be a total waste of time and $30... But I'm bored and like working on cars ;-)
I do the same thing with computers. I'll put a new heatsink/fan on my processor or graphics card just to cool it down 2-6 degrees Celsius...something to do...
nothing
PostPosted: Wed Jan 07, 2009 1:40 am
vtruss8 wrote:
I can get a Bosch Oxygen ........
Not that I have any experience in this area, but Bosch products are not very popular in the 3800 community.
vtruss8 wrote:
........ something to do.
In that case, I will not waste any more of my time.
PostPosted: Wed Jan 07, 2009 7:13 am
Geez, thanks for being so kind there bud....You have a good one too...
nothing
PostPosted: Wed Jan 07, 2009 6:20 pm
I've read about the 'distaste' for Bosch products on 3800pro, but I don't understand why nearly every other OEM "crowd" doesn't seem to have a problem with them. Maybe it was a bad run, maybe it's just unfounded speculation, but I don't see a reason for the car to care what brand the sensor is.
But, like Norm, I don't have much experience with the 3800.
PostPosted: Wed Jan 07, 2009 9:58 pm
........ I don't see a reason for the car to care what brand the sensor is ........
There was a day when Champion spark plugs were the choice of most independent mechanics, for use in all makes and models of American cars.
When computerized engine management arrived, they did not work well with the Champions. Erratic idle, misfiring, etc, was the result. Changed to OEM brands, and the problems disappeared.
Happened to GM and Fords all over CA. I cannot speak to Chrysler and/or the other 49.
PostPosted: Wed Jan 07, 2009 10:06 pm
That's quite interesting. I wonder if there is something specific about the engine management system that differs from other similar types that causes some sort of interference.
If I had more time, money, and a 3800, I'd probably look into it. :lol:
I suppose in thinking about it though, I work on a lot of (small) engines that don't "agree" with certain spark plug types, mainly Champion.
Thanks for the insight Norm.
PostPosted: Fri Jan 09, 2009 12:24 pm
you wont have any problems with bosch o2 sensors bosch sucks though when it comes to sparkplugs and wires for the 3800's and various sensors, for some odd reason, but i have to ask 350 miles to a tank, are you attributing city mileage or straight highway mileage.......???? dont just assume its your o2 for that reason and damn sure dont replace just the oxygen sensor without checking the current condition of your regular tune up items (spark plugs,wires etc....)
