 Page 1 of 1 [ 10 posts ]
 Post subject: 69 Cutlass S problems
PostPosted: Thu Mar 05, 2009 6:51 pm
I'm just getting into car repair myself, so I have no background to go off of here. I have a 69 Cutlass s with a 455 bored up to a 461, but it has issues.
-E-brake light stays on, and as far as i can tell it is disengaged.
-While it does start, it seems that I can't make it more than 2 miles any more before she dies on me, with the solution seeming to be either wait a while or get a jump.
-Even when it is running, it develops what can best be described as a "clanking" sound that grows in frequency the longer its driven.
The alternator has just been rebuilt, the fuel filter is good, and the battery checked out alright. Any advice for a novice?
PostPosted: Fri Mar 06, 2009 3:10 am
Hi d.roy4751,
........ 455 bored up to a 461 ........
Since a thirty (.030") over 455 is a 461, the phrase is redundant.
Depending who I'm talking to, mine is a "455 Olds", a "sixty over, 455", or (in the case of a serious gearhead) a "twelve to one, 468".
........ E-brake light stays on ........
The switch (should be near the top of the pedal), is not opening when it is released.
........ can't make it more than 2 miles any more before she dies on me, with the solution seeming to be either wait a while or get a jump ........
Not much to work with. Does it die while you are moving at a steady speed?
When it dies, does the starter crank (turn) the engine as it should?
Does it start if you jump it immediately after it stalls?
Does it happen again? Is the time lapse the same? More? Less?
Next time it happens, remove the gas cap immediately and try to restart it.
........ it develops what can best be described as a "clanking" sound ........
Even less to work with. Does your oil pressure light go on with the ignition switch, then go off when the engine starts?
........ that grows in frequency the longer its driven ........
Does it vary (increase/decrease) with engine RPM, or with vehicle speed?
PostPosted: Fri Mar 06, 2009 1:57 pm
Hi D
The park brake light on could be caused by an issue in brake fluid pressure or fluid level.
have the level inspected, or use the owners manual to inspect the level yourself.
be very careful, the fluid can damage painted surfaces!
when your engine stalls- does it crank ok?
your clanking sound could be anything from loose torque converter bolts, to an exhaust leak.. to ...well, anything.
do you notice anything else about the problem you can help to describe it?
PostPosted: Fri Mar 06, 2009 6:31 pm
stever wrote:
........ The park brake light on could be caused by an issue in brake fluid pressure or fluid level ........
If you will take a look at your '67, you will find that its E brake is cable operated and is not related to its hydraulic system, in any way.
The '69 that is being discussed is no different.
The switch (should be near the top of the pedal), is not opening when it is released ........
As illustrated below:
PostPosted: Fri Mar 06, 2009 6:40 pm
d.roy4751 wrote:
I'm just getting into car repair myself, so I have no background ........
Purchase of a Factory Service Manual is a good start.
PostPosted: Sat Mar 07, 2009 11:27 am
It typically dies when coming to stops, however it did once at a steady speed. The starter does crank, but I can't try too many times before it becomes noticeable that it isn't going at full strength. Jumping does help about 10 minutes after (about the time it takes for a motorist who actually tries to help to finally come by), however the time lapse until when it died again seemed to decrease.
PostPosted: Sat Mar 07, 2009 5:59 pm
If the points/condenser have not been replaced within the last 20,000 miles, replace them.
If they have, replace the condenser only.
PostPosted: Mon Mar 09, 2009 2:27 pm
have a look at the wire plugging into your proportioning valve, found mounted to the driver side frame rail, behind the driver side torque box.
its a pressure sensing switch that sets off the parking lamp if brake fluid pressure drops too low.
restoring ;) photos
http://s42.photobucket.com/albums/e315/ ... on%20pics/
PostPosted: Wed Mar 11, 2009 2:46 pm
take a looky here,
great forum there too
http://classicoldsmobile.com/forums/cut ... -dash.html
restoring ;) photos
PostPosted: Thu Mar 12, 2009 3:14 am
stever wrote:
........ great forum there too ........
It is.
