It is currently Sun Oct 25, 2026 3:03 pm
PostPosted: Mon Aug 24, 2009 8:50 pm
Good Evening,
Olds 94 Eighty-Eight Royale 6 cyl
Hope someone can help. When I run the AC, on a hot and humid day, the condensation that it collection comes splashing out from behind the bottom panel into the passenger floor. It is a lot of water too. I can't get under there to see if it's a misplaced/busted hose or what...
Anyone know where this is coming from? How to fix it?
TIA
-Russ
nothing
PostPosted: Mon Aug 24, 2009 9:01 pm
Most likely a plugged evaporator drain hose....had the same problem on my Intrigue.
Should be a 90 degree elbow coming out of the firewall, somewhere around the blower housing (can't tell from my info). It's on the passenger side of the firewall, usually near the bottom. Not even sure it's a rubber elbow...it was on my intrigue. All it usually takes is a little squeeze and water will come gushing out.
Recommend using a wet/dry vac to suck as much water out of the carpet/floor as possible.
