It is currently Mon Apr 29, 2024 2:30 pm
Ankomst
Posted: Wed Jun 30, 2010 3:29 pm |
TOC Member |
Joined: Tue Jan 26, 2010 2:44 pm Posts: 47 Location: Chicago
It is definitely possible to replace an engine and transmission, but you should do your damnedest to at least match makes (GM with GM, Ford with Ford, etc.). My boyfriend and his father rebuilt an '87 Mustang, and dropped a completely custom engine into it that was based on a Ford engine. It's strictly a drag racing car, but the principle remains the same. I'm no expert, but I'm going on what I know, here.
I would suggest checking EBay, and your local Auto Classifieds. In our area here we have magazine racks in our local restaurants and grocery stores containing things like Auto Focus, Windy City Wheels, and Illinois Auto & RV (which is by far the best for classic cars and non-conventional vehicles). Just recently I saw an ad for a nearly-new engine. Those are your best bet unless you know someone who can build you one, or if you can do it yourself.
EDIT:
When I checked through our Classifieds, this is what I found (just as an example):
CHEVY HIPO ENGINE. Small block, complete, 350+ .040 bolt, forged pistons & crank, balanced, mostly new, alum. heads, water pump & intake, HEI, LT4 hyd. roller cam, 400+ hp., can hear run, call for info. $3,500 OBO. Granger, IN.
If you look, every once and awhile you find a gem. Just don't lose hope, and you'll find what you need.. Especially between everyone here and at the summer events all of us will undoubtedly be attending. Even if you pick up a "donor car" whose body is falling apart but whose engine and trans are in working order, it may be worth it.
Good luck!
Posted: Fri Jul 02, 2010 1:01 pm |
TOC Member |
oxoovooxo wrote: ........ as far as i now the old engine is a v8 5ltr 307 ......... Image shows the casting numbers, and their location next to the oil fill tube, on a 350 Olds block. If your numbers are 556607, you have a 307 Olds. Quote: ........ how or where do i get a new engine ........ Highly unlikely you would find a new Olds engine. Quote: ........ is it possible to buy a new engine that will match up the car including transmission ........ Not unless you can find that Olds engine that probably does not exist. Quote: ........ i noticed at a lot of car shows that most of the engines are new ........ Some might be new, but most are either rebuilt, with some shiny accessories added, or just steamed and/or cleaned and painted, with some shiny accessories added.
The most practical choice is to rebuild the one you have.
Posted: Fri Jul 02, 2010 1:22 pm |
TOC Member |
Ankomst wrote: ........ Chevy ........ Engine mounts don't line up, starter is on the wrong side, trans won't bolt up, and none of the accessory brackets will work. Ankomst wrote: ........ Small block, complete, 350+ .040 bolt, forged pistons & crank, balanced, mostly new, alum. heads, water pump & intake, HEI, LT4 hyd. roller cam, 400+ hp., can hear run, call for info. $3,500 ........ For the same money, he could rebuild his 307, and know it was done correctly.
Posted: Tue Aug 17, 2010 4:14 pm |
TOC Member |
oxoovooxo wrote: Oldsmobile Regency 98 with a 6.6 engine ........ Assuming 6.6 = 403 cubic inches: Externally your 307 and the 403 are the same and all mounts, accessories, brackets, etc, will interchange. oxoovooxo wrote: ........ also i am guessing the electrical systems would be different? Unless it is emissions/computer related, everything will interchange. Use the 307 carb, distributor, sensors, etc. Norm
