It is currently Sun Oct 25, 2026 12:59 am
 Page 1 of 1 [ 1 post ]
PostPosted: Thu Sep 30, 2010 6:55 pm
I corrected a problem with the passenger door handle. That's the one where if you attempt to open the door, using both inner and outer handle, a link jumps out of its slot and then you can only open it from the inside. I put a couple of nuts on the rod for spaces and now it works fine. But that isn't the prob.
The window motor on that door is not getting current. I've changed the relay, plugged the plug into a new motor (which I was gonna install anyway)--nothing. Fortunately, I have the factory manual with the schematics. That's my next step. Has anyone encountered this prob?
The driver's side works OK but when you use it a lot, it will finally stop and you must play with it, moving it by hand and the button until it's closed. Replacing that motor is next.
John
Users browsing this forum: Google Adsense [Bot] and 23 guests
