It is currently Fri Nov 20, 2026 9:26 am
oldsmobile420
 Posted: Mon Apr 12, 2004 11:47 pm |
| TOC Village Ricer |
Joined: Sun Dec 21, 2003 2:05 am Posts: 223 Images: 20 Location: pa
ok when i have it in park it gots to high of a idle it start s ldleing really high and when i have it in neutral it gets a little beta but when i put it in drive it completey stops and is all beta can any 1 tell me what may be wrong
_________________ my 88 cutty http://www.cardomain.com/memberpage/478908 may she r.i.p
 Posted: Tue Apr 13, 2004 12:02 am |
speedy266 wrote: do u have the 3.8?
Nah...he's got the ol' Tech 4!
oldsmobile420
 Posted: Tue Apr 13, 2004 12:06 am |
| TOC Village Ricer |
speedy266 wrote: Is this all the time? or is it only when the engine is first started? Does the idle go back down in park and neutral when the engine is warm? Its normal for the car to have a high idle in park and neutral when the engine is cold. If it is still fairly high after it is warmed up, i think u may need to adjust ur idle screw. im not sure wat the TPS voltage is at idle for ur car, do u have the 3.8?
no its all the time no it does not go back down when warm and brando is right i got that dam tech 4 iron duke at least for now till next summer when it gets a 3.3 v6
 Posted: Tue Apr 13, 2004 1:04 am |
oldsmobile420 wrote: at least for now till next summer when it gets a 3.3 v6
Why the 3.3?
If you're gonna upgrade, I would go with the 3.8L V6!
 Posted: Tue Apr 13, 2004 8:22 am |
3.8's are good!  If it pushes my 3500 pound grampa car as good as it does, then your little machine would just HAUL! (cheap motor and reliable too)
73Delta88
 Posted: Tue Apr 13, 2004 11:54 am |
don't waste your effort.... unless you found a FREE engine or something that would be more hassle than it's worth to convert and install.
strokercutlass
 Posted: Tue Apr 13, 2004 10:34 pm |
| TOC Mechanic |
so..when you buy that 3.3 for $150, does that include the transmission, the ECM, the complete engine compartment wiring harness, all the mounts, and everything ELSE needed to install a 3.3 in your car, originally equipped with a 2.5 tech 4? Just curious......
 Posted: Tue Apr 13, 2004 11:16 pm |
strokercutlass wrote: so..when you buy that 3.3 for $150, does that include the transmission, the ECM, the complete engine compartment wiring harness, all the mounts, and everything ELSE needed to install a 3.3 in your car, originally equipped with a 2.5 tech 4? Just curious......
I'm kinda interested too :?
Plus, the Ciera didn't even come with the 3.3 in 88'.
Although...the Ciera did come with a 3.8! 1988 Oldsmobile Cutlass Ciera, 2.5 L4, 2.8 V6, and 3.8 V6.
73Delta88
 Posted: Tue Apr 13, 2004 11:43 pm |
like I said before.... it's going to be a major bitch to do that, but if you can get all the parts you need for next to nothing and you really know what you're doing, I guess I'd say go for it.
if you really want something with a 3.8 I know where you can get a 1993 Ninety Eight that's in great condition!  it's not a "fast" car but I'm sure it would beat the pants off what you have now!
