It is currently Fri Nov 20, 2026 8:34 am
 Page 1 of 1 [ 8 posts ]
PostPosted: Thu Apr 15, 2004 11:36 pm
TOC Village Ricer
TOC Village Ricer
Images: 20
ok i want to run 2 amps and a shit load of neon s am i gonna have to upgrade my alternator to a 105 amp or can i run that stuff off my 85 amp and get a way wit it
PostPosted: Fri Apr 16, 2004 12:26 am
Images: 23
Just depends on how big of amps.. on my old 88 i had a 700, a 444 and my head unit running with two 100 watt foglights and my headlights.. and they did dim considerably, i felt like a cop when i went down dark streets..lol
PostPosted: Fri Apr 16, 2004 1:08 am
Tell us what the fuses are on the amps....and do they dim now when the bass hits? A shit load of neons? About how many? Neons actually don't use that much current....around 1.5 amps per neon I'd say...
PostPosted: Fri Apr 16, 2004 6:48 am
I think I can help you guys a little here. I have been told that BIG stereo systems can put a load on the charging system, then you start to see the lights dim etc like Brando described. But, they pull lots of amps. A 2 amp neon system will not load down a properly working stock charging system. Ricerdude, you won't have to worry about upgrading your alternator. Just be sure to have your neon circuit properly fused. If the manufacturer recommends 2 amp fuse then that works, or whatever they say use it. To give you guys an idea of what 2 amps means to charging circuit as far as what kind of load it represents, I have my 16" cooling fan fused at 30 amps. If you guys look in your owners manuals you will see that things with electric motors usually have larger fuses on them, like heater/defroster systems, and engine cooling systems (Although the cooling fans may not be fused at the fuse box but maybe with an inline fuse in the wiring harness). Another thing that draws a lot of amps (current) is heating elements like in houshold dryers although that doesn't apply to us here. Incandescent lamps draw more current than LEDs which I think is what "neons" really are, but I am not sure. The might really be neons, but even so, old style incandescent lamps draw more. You won't have to worry.
BTW, I am not talking out my **s, I have worked in electronics since 1975, this stuff is basic Ohms Law theory, so believe me....Ricerdude, just follow the directions on the neon kit and you will be fine. Good luck.
PostPosted: Fri Apr 16, 2004 8:35 am
only way to know is to runtest it.
PostPosted: Fri Apr 16, 2004 8:38 am
TOC Village Ricer
TOC Village Ricer
Images: 20
well when we put the new system in last night i saw some dimming and forthe neons i want the neon rings the under body light kit two under dash 2 in the trunk and 1 on the back deck
PostPosted: Fri Apr 16, 2004 9:38 am
what kind of amp are you goin to have to power the sub's and what kind of subs? also i love the wing on your car. it kicks ass. also do you have your car up on Car Domain yet? if not you should right now i am #1 in the 1994 olds cutlass ciera part of it. thanks and i hope you vote on my car on cardomain. good luck with the system.
Rusty Froman
President and Founder of Simply Irresistible Car Club
http://sicc6.tripod.com
http://www.cardomain.com/memberpage/347561
PostPosted: Fri Apr 16, 2004 9:57 am
TOC Village Ricer
TOC Village Ricer
Images: 20
im gonna get another jensen amp and my subs are audiobahn 10" ill be posting for pics tonight btw look in my profile there u will c my website hit that up for my cardomain.com o and by the way at least some one likes the wing i got on there
