It is currently Fri Nov 20, 2026 9:42 am
 Page 1 of 1 [ 8 posts ]
 Post subject: loss of power?????
PostPosted: Thu Apr 22, 2004 8:40 pm
my 91 olds cutlass ciera has been losing power recently it takes more gas to get it going than what it used to i have replaced plugs and wires and i have no clue what else to try if anyone else has any ideas it would help out alot
Justin
PostPosted: Thu Apr 22, 2004 9:41 pm
clogged fuel filter? low tire pressure, bad gas, air filter? PCV Valve? just some suggestions
PostPosted: Thu Apr 22, 2004 9:58 pm
not sure about the fuel filter never been changed not sure how to change it... tire pressure is ok and the gas is fine, not sure where the PCV valve is..thanks for your help man.....any other things i might check?
PostPosted: Fri Apr 23, 2004 12:41 am
TOC Village Ricer
TOC Village Ricer
Images: 20
really check ur air filter mine was bad and i lost some power but i got it clean and works great now
PostPosted: Fri Apr 23, 2004 8:29 am
yeah air filter will cause exactly what you've described.
PostPosted: Fri Apr 23, 2004 8:46 am
just replaced air filter yesterday when i changed the oil :( it mostly loses power when it has been driving for a while then it seems that it just doesn't want to go
 Post subject: pcv
PostPosted: Fri Apr 23, 2004 9:59 am
haha thats me..needing a new pcv valve :p ahaha
PostPosted: Fri Apr 23, 2004 9:17 pm
I'd definetly get the fuel filter changed, just as a precaution, ESPECIALLY since you have never done it yourself and don't know the last time it was changed....
