It is currently Fri Nov 20, 2026 10:02 am
 Page 1 of 1 [ 8 posts ]
 Post subject: door lock broken
PostPosted: Fri Apr 23, 2004 2:23 pm
My drivers side door lock is broken i locked my keys in my car one day and the police tried to get them out with a lock thingy and now the key will just spin in the door its really annoying to have to walk to the passenger side to unlock my car then walk around if anyone know's what's wrong let me know....
P.S. i just wanted to let u all know i am so glad i found this forum u all are very nice even after all my questions and i just wanted to say thank you for everyone's help :D
 Post subject: Re: door lock broken
PostPosted: Fri Apr 23, 2004 6:02 pm
Thats the whole idea of this site, is to help eachother with our cars. The more questions the better, because your question may help someone else with the same problem.
As for the key thing, you may need another lock, they should have that at a GM dealer or of course the local junk yard. :D
PostPosted: Fri Apr 23, 2004 9:09 pm
Images: 9
I had the same problem only I put the coat hanger down myself and started moving it around... Wrong move. While I was fiddling around, I heard something drop to the bottom of the door and I knew I broke something -_-;
I finally find the spare keys, open the doors and turned off the engine (hehe yeah I turned it on and somehow locked myself out), opened the panel and looked to find I had broken this plastic piece that connected some rod to the handle...
I couldn't fix it so I fabricated my own rod that was longer and could make up for the lost area where the plastic piece had resided before.
Yep... kinda irrelevant but yeah, hehe.
PostPosted: Sun Apr 25, 2004 1:13 am
i bet there is just a rod connector that is damaged on your lock. its just a little plasic thing that holds the pushrod in place. Maybe it just fell off even? take the door panel off and look.
PostPosted: Sun Apr 25, 2004 1:24 am
haven't tried to take the door panel off yet looks complex
PostPosted: Sun Apr 25, 2004 1:27 am
just use care, dont force anything, or clips will break. But it is quite simple, after you find the 3 or 4 (possibly more on your car) screws that they commonly put on the doors. The rest are pry-off plastic clips, use a wide, flat blade screwdriver to gently pry them out so you dont break them. Putting it back together is WAY easier, and you'll know how to do it for next time.
 Post subject: hhhah
PostPosted: Sun Apr 25, 2004 12:23 pm
ya my back right door has a lil mirror in it now cause i forgot to take it out before i put it back togethere :p
PostPosted: Sun Apr 25, 2004 6:22 pm
On my ciera, there are 4 screws that hold on the armres, 2 tha hold on the door locks, etc part and I think the rest is the clips.
