It is currently Fri Nov 13, 2026 12:07 am
strokercutlass
 Posted: Sat Apr 24, 2004 11:29 pm |
| TOC Mechanic |
sounds like perhaps you brought the marks up 180 degrees off, when the piston was on the exhaust stroke....if the car was that far off regarding the timing, it probably wouldn't run at all, let alone idle smoothly.
strokercutlass
 Posted: Sun Apr 25, 2004 1:37 am |
| TOC Mechanic |
try this...turn the engine till the rotor is pointing at #1 cylinder, and see where your marks are...on some cars there can be more than one mark, depending on how its timed...
 Posted: Wed Oct 27, 2004 3:34 pm |
Hi Speedy, hello All
Quote: .............advancing timing adds a little more HP............. Try this linkQuote: ..........Would that be a matter of loosening the distributor and turning it slightly........... Yes, see the above link. Quote: ....... or does that mean that the camshaft has to be slightly ahead of the crank? Other than factory/camgrinders recommendations, changes in camshaft settings are determined by dynomometer sheets and/or timeslips. See the above link.
Define your goal.
Then you'll be able to work out and execute a plan, involving an engine swap, or compression, cam, and fuel delivery in your present engine, and probably more money than you'll want to spend.
