It is currently Tue Nov 24, 2026 2:35 pm
 Posted: Sat May 01, 2004 11:38 pm |
speedy266 wrote: lubricating the throttle body springs and moving parts with WD-40 and lubricating the TPS sensor.
Hi speedy266, Hi all
Good thinking, everyone should do the same, although WD 40 is a solvent, not a lubricant, and the cleaning should be followed up with silicone spray for lubrication.
 Posted: Mon May 03, 2004 9:23 am |
I noticed a big difference in smooth, uniform acceleration when I replaced my TPS sensor. It would follow my foot control a lot more accurately than before.
 Posted: Tue May 25, 2004 8:20 am |
I adjusted mine to read .38 volts. This is as close as I could get to the recommended .4 volts as I could without modifying the TPS sensor mounts, or jacking up my idle speed.
Since you're going around all over the top of the engine, check your pcv aswell...
Anyone know how to test for an intermittent Crankshaft Position sensor?
MysterHK
 Posted: Tue Apr 25, 2006 10:11 pm |
Aaron, I got the answer for you, but I need to know what type of ignition system you have in yours, a Type I or a Type II, because the tests are completely different for the crank sensor based on the ignition type.
I looked hard at your engine pic and seeing how high on top it's situated, I can't really be certain of the plug connection arrangement.
If your top surface profile of your C3I module & coil pack has 3 connections to the left and 3 connections to the right of the coil pack bank, you have a Type I ignition. Each individual coil block has one connection on each side. (Mine, is a Type I.) If however, you have 6 connections all on one side of the coil pack bank only, with 2 connections per one side of each individual coil block, you have a Type II.
