It is currently Fri Nov 20, 2026 1:19 pm
 Page 1 of 1 [ 6 posts ]
 Post subject: Catalytic Converter?
PostPosted: Mon May 10, 2004 10:12 am
Images: 12
I need to install a new Cat in my car,
and i have nevre done any of my own exhaust work and iam going to tackle this one on my own, because i dont feel like paying some jackass $80.00 an hour to do a job for three hours (juts useing time as my point) and he is going to get paid for 5 or 6.
So can anyone give me some tips on wheather it is fairly easy?
or some pointers.........thanks
PostPosted: Mon May 10, 2004 5:02 pm
Well, if the original cat is welded in, you will have to cut it out. Can you weld? If so, that would be easier than using a hacksaw. I am betting you can't weld (like me) so you have to do it the old fashioned way. First, make sure the new cat has the correct inlet and outlet size to fit OVER the exhaust pipe in the car and that it is the correct length as well. Use some good safety stands, if you don't have any, don't do it in the driveway. You might have access to a lift, if so, no problem. At any rate, use safety goggles if you are going to hacksaw the old cat out, metal filings in the ol' eyeball suck :cry: Be ready for some tired arms, because it will take some time, if you have a power saw all the better. Use some bailing wire on the front and back pipes to hold them up when you cut out the cat. When the old one is out, put the new one in, use some new clamps (they probably come with the cat), and clamp those suckers down tight, but before you tighten them, snug them and make sure everything fits well and the cat is parrallel with the bottom of the car and won't jiggle or bump up against the floor pan when you hit bumps in the road. Then tighten everything up real tight and there ya' go. Good luck.
 Post subject: SHITTY :)
PostPosted: Tue May 11, 2004 12:40 am
thats funny you mention safety glasses :p i just got a metal shaving in my left eye today :( i thought i would be fine...but i wasnt...it sucked..you will figure out wha i was doing in my soon to be postabout what i did today and doing tommorow...
PostPosted: Tue May 11, 2004 12:48 pm
Images: 12
Thanks alot,
and yes i do know how to weld, but i have never welded anything on a street car,
I have been welding race cars for a few years,
So i might just get a friend to help me, he has welding certificates..lol
Thanks again. :D
PostPosted: Sat May 22, 2004 12:48 am
hey Frop, i was wondering if u got around to getting ur cat off? Is it welded? or is it held on by bolts and clamps?
PostPosted: Thu Jun 24, 2004 12:54 am
Images: 3
metal shavings in the eye - use a magnet
aluminum shavings in the eye - u are screwed
-use safety goggles
The world is a diaper so let someone else change it...
