It is currently Fri Nov 20, 2026 11:39 am
 Post subject: Cleaning An Engine
PostPosted: Wed May 12, 2004 11:56 am
I was looking through the album and saw 88delta88's before and after engine cleaning pics...
Does anybody have any tips on cleaning an engine? Products you used? Things to be careful of?
Thanks
PostPosted: Wed May 12, 2004 12:19 pm
i just cleaned mine use gunk engine brite its in a aresol can make sure the engine has cooled down i let mine sit over nite just to make sure cover up the alternator distributo and anything else electical because electrictiy and water don't mix Spray on the stuff scrub and spray off ... let the car sit for a while to dry and then see if it needs to be done again...look at my car domain site i cleaned mine not to long ago
PostPosted: Wed May 12, 2004 12:28 pm
I would say any "engine degreaser" is a good bet to use, the foaming stuff works better I've heard, but I usually just use simple green.
Like any chemical, the longer you leave it on the engine, the more grease it will attack, but also has a greater chance of staining or fading paint on parts in the engine compartment. Also, avoid getting it on your car's body, it will strip the wax off the paint. Thats all I ever do, when I wash it off, a shiney new engine compartment is all that is left :-)
PostPosted: Wed May 12, 2004 2:48 pm
I like using Bleach-Wite... if it's REALLY bad, use the Foam Gunk and then do it again with Bleach-wite or simple green. The gunk stuff works good for thick grease, but it leaves behind a Kerosene smell and a foggy finish on any painted parts.
BTW, you will get some cleaner on your front fenders, so just plan on waxing them and the front bumper after you're done. I usually wait until right before I wax my car to clean the engine.
as far as electrical stuff, I've never covered anything, and I've never had a problem. Just avoid spraying a direct stream of water at any major electrical areas and you should be fine. But if you want to be extra safe, it can't hurt to cover them I guess. When you're done cleaning it take the car for a couple laps around the block to heat up the engine and help dry things out right away.
PostPosted: Thu May 13, 2004 8:51 pm
Images: 12
As far as covering anything, the only thing you need to be conserned with is the Distrbutor cap as you don't want water getting in that *nothing BAD will ahppen, it just wont run until it dried out* Also for carburated engines, make sure the air filter stays dry, if you deiced to take the air filter off to clean the intake more thoroughly, make sur you cover up the butterflies *water in engine = bent rods, not good*
As far as battery and alternator and other electronics, don't worry about them as they are actually designed to get wet and are protected against it
I just did my engine about 2 weeks ago and boy did it need it, all i did was take some saran wrap, and wrapped the sitrubtor and put some over the butterflies on my carb and sprayed away *i went to one of them self serve car wash places and used their pressure washer ;)
When i got done, started it right up, and pulled off to the side and used some paper towels to soak up the standing water on the runners, and i was on my way :)
-Shadow's Rides-
