It is currently Fri Nov 20, 2026 11:11 am
 Page 1 of 1 [ 7 posts ]
 Post subject: fuel filter
PostPosted: Wed May 12, 2004 12:21 pm
So i am thinking about chaning my fuel filter i know where its at i just dont know how to go about changing it do i just unclamp it and change it or do i have to drain the gas...any help or steps to do would be greatly appreciated
PostPosted: Wed May 12, 2004 2:19 pm
You just loosen the bolt and clamp or however it is held up. Some gas will leak out watevers in the lines and fuel filter, pop the new one on, make sure its tight, start her up and check for leaks. If u got none, ur good to go.
PostPosted: Wed May 12, 2004 11:46 pm
Now...the things speedy DIDN'T tell you.....
On these cars, the fuel filters are located underneath the car either at the rear, by the gas tank...or under the drivers side rear door along the frame. Either way you WILL have to get under the car a ways....
NOW, the majorty of these cars used a filter which is fastened into the fuel line with fittings at each end. Since this most likely never had a fuel filter replaced, this means the fittings will be rusted and probably won't come loose without a fight. If you twist the line or strip the fittings, you're pretty much screwed.
If theres ANY kind of rust on the fuel lnes if the filter is located under the passenger door, you can almost guarantee either
A. a broken fuel line from so much rust....
B. broken brake line fom rusted/ thin tubing...
or C. numerous combinations of both A. and B.
If its a rear style mount, it may have a fitting on one end, and a hose/clip assembly on the other....depending on the filter, you may have to reuse the clip, some companies don't throw the clips in....DON'T twist the synthetic plastic fuel line if it has one...you're screwed once more....
Do you see a pattern forming here?
If you've never attempted replacing one of these, or don't have any experience at this....DO YOURSELF A FAVOR!!!! take it into the shop and have it done there....they have the knowledge to tackle this, plus can get under the car to do the filter, as well as inspect the lines for rust damage.....
OR....
Make sure you have AAA before you try it....just in case you need a wrecker later on :wink:
PostPosted: Thu May 13, 2004 1:20 am
He said he knew where its at, but yah thanks for the cover. I dont think it should be rusted 2 bad cause hes been using the car, if its been sitting for a long period of time than it would probably have rust build up. Just spray some WD-40 over it and let it soak in a bit before u loosen it should help.
PostPosted: Thu May 13, 2004 8:15 am
i like liquid wrench. anyone use that stuff here?
PostPosted: Thu May 13, 2004 9:49 am
today i shall tackel the fuel filter thank you all for the advice it is much appreciated ;)
PostPosted: Thu May 13, 2004 12:08 pm
if its under the car like stroker says, it will be rusted.. just driving in the rain a few times is enough to do this
1995 Saturn SL2 (SOLD)
