It is currently Fri Nov 20, 2026 10:44 am
 Post subject: Burning Oil
PostPosted: Wed May 12, 2004 9:22 pm
My car has burned oil slowly since I got it. There is no noticable burn in the exhaust and it does not leak (not noticably at least). Any ideas on how to fix this? I just had to add 2.5 quarts to get the dipstick at the right place.
PostPosted: Wed May 12, 2004 11:51 pm
:shock: :shock: :shock: :shock:
You realize you've only been running that car with about half of its capacity??? If the car burned oil THAT fast, you'd see it, which means you rarely open the hood and check anything.....a car your age will have some oil consumption issues, but I'm betting if you checked your oil on a regular basis, you'd find its not going down as quick as you think. What made you decide to check the oil? Oil light coming on? You said yourself that the car has slowly burned oil, which means you should KNOW to check it more often......
Theres no easy way to tell where the oil may be going without inspecting the car personally......
PostPosted: Thu May 13, 2004 12:58 am
I usually check it often, try to everytime I fill up, recently I've not been as much because it seemed to stop doing this after I flushed it with some stuff. Usually it doesn't get this bad...
PostPosted: Thu May 13, 2004 8:21 am
some people have said in the past that when they CHANGE thier oil and it is fresh, not sandpaper, it burns less quickly. I am maybe thinking the oil breaks down as you use it and it becomes less thick, letting more oil down through the valves and up the rings.
do you normally use 5w30? Try 10w30 and see if there's a difference...
Does your car leave oil spots on the driveway? If so, thats where a lot of it likely goes. I lose a quart a month from my car's leaking oilpan gasket (gotta fix that, it makes a hell of a mess in my garage!).
