It is currently Fri Nov 20, 2026 11:43 am
 Post subject: Turnsignal not flashing
PostPosted: Wed May 19, 2004 5:15 am
Hello!
Just suddenly my left turnsignal stopped flashing. When turning it on the signal just keeps beeing illuminated and will not flash. Did not notice anything unusual before it suddenly got this way. Guess it must be the relay or something...
Anybody have any suggestions?
All answers will be greatly appreciated!
1973 Delta 88 Royale
12k orig miles
PostPosted: Wed May 19, 2004 7:24 am
You have a faulty indicator lamp or wire, if it was the flasher unit both sides would not work. First thing to do would be to switch the lamps from right to left side, if the problem switches sides, you know it is the lamp. If the problem doesn't switch sides, it is in the wiring for the bad side. Good luck.
PostPosted: Wed May 19, 2004 6:50 pm
definitely check the bulbs first.... mine used to do that too :D I changed all the sockets in the rear tail lights because they were kinda corroded.
PostPosted: Thu May 20, 2004 7:07 pm
mine did that, try cleaning the contacts or wiggling it around a bit till it lights up
1995 Saturn SL2 (SOLD)
PostPosted: Thu May 20, 2004 8:04 pm
check the bulbs first,on those old cars the sockets get rusty fast
check that out and make sure ya clean the sockets too
