It is currently Fri Nov 20, 2026 12:27 pm
 Page 1 of 1 [ 8 posts ]
 Post subject: Gas Guzzler
PostPosted: Mon May 31, 2004 5:56 pm
My 83' Delta 88 is eating mad gas. Me and my stepfather have checked a lot of stuff out on it. There is nothing wrong with the fuel line. No one can siphen gas out of my tank b/c I have a locking cap. So i'm just wanting to get feedback on what could be done to increase fuel efficiency.
PostPosted: Mon May 31, 2004 6:14 pm
Well, how long have you had the car? If you just got it then you need to know that those large rear wheel drive Olds arent too good on gas. Also keeping proper tire pressure helps to save gas.
PostPosted: Mon May 31, 2004 6:32 pm
I've had it about 9 months. This just started happening about 2 weeks ago and its killing my wallet. I handled the tires and they are at proper pressure.
PostPosted: Mon May 31, 2004 6:38 pm
Now Im no mechanic, but that car should be carberated if its a V8, V6 I THINK is fuel injected (3.8 litre Buick V6). Maybe some STP fuel system cleaner, that stuff that you dump into the gas tank. They have it for fuel injectors or your whole fuel system. Also maybe you should clean your carb? Just a shot in the dark, but hope I helped!
PostPosted: Mon May 31, 2004 8:29 pm
i would recommend changing air filter and getting some "Lucas" fuel treatment..good stuff..
also have you recently changed where you get fuel?
all fuels are NOT created equal..
1988 Cutlass Ciera SC
Torque(lb-ft)-215 @ 2750 RPM
Displacement- 3802cc
4 Speed Automatic
This WAS My Dad's Oldsmobile
 Post subject: Re: Gas Guzzler
PostPosted: Mon May 31, 2004 11:14 pm
Just how "mad" are we talking here?
PostPosted: Tue Jun 01, 2004 12:02 am
lucas fuel injector cleaner & upper cylinder lubricant the best for ur fuel system!
PostPosted: Tue Jun 01, 2004 8:52 am
no vacuum leaks anywhere? that'll cause rough milage. so will bad timing, improper choke adjustment etc...
sounds like a carb kit in the future? they're cheap compared to gas.
