It is currently Fri Nov 20, 2026 1:37 pm
 Page 1 of 1 [ 14 posts ]
 Post subject: A/C HELP!!!!!
PostPosted: Wed Jun 23, 2004 9:54 am
When I turn on the a/c in the Olds, the fan comes on, and air blows through the vents. This air is slightly cooled but no where near what it should be (I think its only cooled because the fan is cooling the engine at the same time). The system doesnt appear to have any leaks, and my aunt said that last summer it worked fine. The belt for the compressor works, but I dont know how good the compressor is, it has this sticky black stuff on it ( I think is called referigerant oil) and the center of it moves (the part that the belt is on) but not the side of it (which appeared to move last Feb. if I remember correctly. I also know that the condencer fines and other such parts havent been cleaned or even checked in the last 6 years maybe longer. When I turned on the heat it was quite hot. If it makes any difference a few years ago the water pump was replaced. I changed the radiator hoses and the termostate ( if they are wrong would that change the a/c's ability to work?) :oops: :roll: :x
PostPosted: Wed Jun 23, 2004 10:50 am
Also the compressor belt starts to move with the engine, so I dont know if its moving really means anything. I cleaned the air vent on the cowl when i got the car so its clear, and the fan is ok, it moves nice and quick. Could the system need to be charged? How whould I know?
If it needs a new condencer, any idea on what that would cost (to have it installed)?
PostPosted: Wed Jun 23, 2004 10:57 am
I added a pic of what the part in question looks like, in the album. If you have any idea PLEASE post them!
PostPosted: Wed Jun 23, 2004 12:07 pm
ok... sounds like your ac system is in need of a recharge. The refrigerant leaks out of the system over time, and even though it worked last year, it might have leaked over that period of time.
When you switch the AC on, you should feel the engine bog down for a couple seconds at a time, every 30 seconds or so. This means the compressor is cycling. This is good.
the radiator for the ac system should not cause problems if the fins are dirty, the system should at least put out cold air for a small amount of time anyways.
When you switch the ac on, go under the hood and watch the compressor. You should see the belt spinning, and when the compressor kicks in, the center of the pulley should spin too, and you'll hear it click on. This means the compressor is compressing :-) This is a good thing, but I feel yours will not do this. If the refrigerant pressure is not high enough, the system will not operate as a safety feature. There is a sensor that tells if there is low refrigerant. I think there is even a way to bypass it for testing, but I am not an AC expert, so I wont go into that.
I think you need to check for leaks on your hoses, and recharge your system (which will be VERY hard to do with R12 refrigerant, you will have to convert it to R134A, unless you know someone who has some R12 sitting around) R12 is old and illegal for environmental reasons. My olds has the same problem, I have to recharge, but I would have to convert the whole system over to the new refrigerant style.
AC is a dangerous system to work on by yourself, so as always, I would definately recommend getting the work done by an AC specialist... Especially handling refirgerant. ;-)
PostPosted: Wed Jun 23, 2004 12:14 pm
I just went out and check a few min ago, the compressor isnt cycling anymore. In Feb, it would bog the engine down, and cycle on and off like it should. I cant see any leaks but that may be it. I dont think the a/c has been serviced in 10-15 years so it may need a charge. Thanks for your help!
PostPosted: Wed Jun 23, 2004 12:27 pm
you wont see leaks in refrigerant, its not a liquid in the environment. The only way to test for leaks is to purge the system, and do a pressure test with air, and spray soapy water on ALL the joints to see if anything is coming out. Dont purge your system by yourself, its very bad for the environment ;-)
PostPosted: Wed Jun 23, 2004 5:35 pm
it's MUCH cheaper to convert to 134a than to buy the R-12 (even if you could find some) Definitely take it to a mechanic who has A/C equipment and have them put the guages on it, I bet it's out of freon. You can't see where it's leaking if it does in fact have a leak, but I've heard that there is a special dye that can go in there that will make any leaks obvious as it leaks out again over time. something worth looking into.
PostPosted: Wed Jun 23, 2004 7:34 pm
Images: 12
Yea what he said :P
r134a is definintly cheaper than r12, and as mentioned b4, is illegal to sell anymore, r134a is 'enviromently friendly' hence why they switched and outlawed r12, anyways, a whole conversion kit costs about 25-35 dollars, which includes everthing needed to convert *even has little cute tiny gauges :) although problem with that is you have to put a vacuum on the system to get rid of the old r12 and all moisture + can detect a bad leak, therefor gotta know someone with the machines.
Also the dye that he was talking about is a leak dye, they use deferent colors for different parts of the car believe it or not *engine, tranny fluid, coolant, etc... i believe for a/c its like a neon green, but it is greatly enhanced under a blacklight for easy finding.
-Shadow's Rides-
PostPosted: Wed Jun 23, 2004 10:43 pm
Images: 23
ive seen the kits in JCwhitney or at checker that have the little UV light and the yellow glasses and all that
PostPosted: Thu Jun 24, 2004 8:29 am
Just to make sure we are all on the same page, that isnt my actural compressor pic that I posted, its a compatable one I found on ebay, so just wanted to let you know, I didnt pull off my compressor, its still on the car.
PostPosted: Sat Jun 26, 2004 12:05 am
As most everyone else has said, it sounds as if the A/C system will need to be recharged. Often if theres a very small leak, you can charge the A/C at the beginning of the season and run through the year. During the winter, when the A/C system isn't being used or circulated, the freon will leak out. In the spring, it's time to recharge again. In many cases, this is the cheaper route to go than replacing expensive parts in the system. In your case, the A/C system will most likley have R-12 in the system. The only GOOD way to remove this is to take it to a shop who has someone licensed in A/C recovery and recycling (In most states, anyone who services and recharges A/C systems must be certified by the state), so it can be removed and then converted to R134. They will then hook it up to an A/C recovery/recycling system, and suck the system dry of all refrigerant, moisture, and the majority of the lubricating oil. This normally takes around 10-25 minutes, depending on the system. Then they will leave the system in a vacuum for anywhere from 20-30 minutes, in which time the machine will attempt to hold a specified amount of vacuum for a certain period of time. In many cases, even if the system passes there may be a SMALL leak, which over time will leak the refrigerant out. They then will change the compressor oil, the A/C fittings, in some cases the orifice tube, and then repressurize the system with oil, refrigerant, and usually a leak detection oil. You may notice a difference in the A/C temperature, as R12 cools better than R134, but in most cases the difference is somewhat insignificant.
PostPosted: Sat Jun 26, 2004 8:56 am
Any idea what this whole thing may cost?
PostPosted: Sat Jun 26, 2004 12:05 pm
Hi 85cieraholiday, hello all
Might cost very little if the problem is a fuse. If its not, the shop should give you options and a price before you OK the work.
PostPosted: Sat Jun 26, 2004 2:37 pm
:-) norm to the rescue... no one thought of that!
