It is currently Fri Nov 20, 2026 2:05 pm
 Page 1 of 1 [ 10 posts ]
 Post subject: Another Battery!
PostPosted: Tue Jun 29, 2004 6:11 pm
About three years ago I bought a Die-Hard battery from Sears, It worked great (it should have, I spent 90 bucks on it) had 1000 cranking amps (900 cold cranking amps). Anyway, it came with a 36 month full replacement warrenty. Over the last couple weeks i've noticed that it's not holding a charge like it should. If the car sits for more than a couple days the battery is always dead. I made sure my charging system is fine, and there is no draw on it when I let it sit (except a very small amount for the clock and radio memory). I try to keep the reciepts for stuff I bought for my car in a folder, so I dug it out and found the one for the battery..... I bought it 35 months ago! that means it's still under warrenty. haha, this is great.... I'm going to get a new battery for nothing. talk about cutting it close! :D
my father bought a battery there also, and he has had 2 free replacements, they both quit about a month or two before the warrenty is up! isn't that wierd?
PostPosted: Tue Jun 29, 2004 7:17 pm
That's nice, get a free battery every time it dies.... 8)
I myself actually just got this battery today. It's pretty damn nice...
PostPosted: Tue Jun 29, 2004 9:02 pm
160 bucks? wow, I guess I did pretty good for $90 then. Although I'm not running any power hogging equipment like amps and such.
they say the lifespan is two to three times a regular battery, but the warrenty is only two years :?
PostPosted: Tue Jun 29, 2004 9:08 pm
Yea...they supposed to last over 10 years....so I think I'll be set for a while :D Oh, and I price matched to this place:
http://www.batterymart.com/battery.mv?p=D34/78-950
So it wasn't too bad...
PostPosted: Wed Jun 30, 2004 11:41 am
They don't pro-rate at all? that's good.
PostPosted: Wed Jun 30, 2004 11:48 pm
D34/78 12 months free replacement + 12 months pro-rated
Question: Why are warranties shorter for deep cycle batteries?
Answer: The more times you deep discharge any battery -- even deep cycle batteries, which are made for that purpose -- the shorter its lifespan will be. But in many applications a battery will be deep discharged only occasionally. In such an application the deep cycle battery will normally last longer than a Red Top battery would. We frequently hear from Optima users whose batteries have lasted eight to ten years (and even more) in non-deep-cycling uses. How long your deep cycle battery lasts will depend on how it's used. The following descriptions outline situations where a deep cycle battery is the best choice:
Situation A: Frequent, heavy deep cyling applications. If your application calls for frequent deep cycling of the battery, you need a deep cycle battery. A non-deep-cycle battery used in such an application will have a short lifespan. Examples include inverter applications, marine trolling motors, frequent winching, and car audio loads beyond the alternator's output (or w/o the engine running.) The largest deep cycle battery that will fit will have the longest lifespan, and it's often advisable to run multiple batteries connected together.
Situation B: Occasional deep cycling applications. Examples include the starter battery in an off-road vehicle equipped with a winch that's used infrequently, or occasional use of an inverter connected to your vehicle. You'll get the best performance and longest lifespan with a deep cycle battery like the D31 or D34 series batteries. And the larger battery (D31), if you have room for it, will have a longer lifespan because it won't need to be discharged as deeply as a smaller battery to accomplish the same task. The less deeply the battery is discharged, the longer its lifespan will be.
Battery Abuse: An additional reason why deep cycle batteries (industry-wide) have shorter warranty periods is that a disproportionate share of deep cycle batteries receive abusive treatment. Abusive practices include failure to recharge the battery after deep discharging, or discharging below the rated minimum 10.5 volts.
PostPosted: Thu Jul 01, 2004 11:22 am
Good info stroker, thanks
PostPosted: Thu Jul 01, 2004 8:35 pm
73Delta88, Hi all
Good post Stroker.
I have always bought the lowest price battery available and they have generally lasted 3 to 5 years.
The original 3 year in my Toyota lasted 7.
The secret is, to never let it get off its top charge.
My two coupes are the exceptions, they each have an Optima in the trunk, as far to the right and as far back as they can be placed.
PostPosted: Fri Jul 02, 2004 9:02 pm
I've had good luck with my Optima red tops so far....I REALLY like the idea of no acid or worry of leakage. I'm thinking about going with the Optima yellow top in the wagon for all the stereo equipment, but the trusty Interstate is holding up well so far...
PostPosted: Fri Jul 02, 2004 9:07 pm
x2 on that...that's one of the reasons I got it, once I installed it, the car noticeably started up a lot quicker, my system is actually disconnected right now because of a broken RCA cable and waiting on some top post battery terminals to get here.
