It is currently Fri Nov 20, 2026 3:16 pm
strokercutlass
 Posted: Fri Jul 02, 2004 9:10 pm |
| TOC Mechanic |
Generally, if the wheel bearings are going bad, you'll hear more of a rumble, more noticeable when accellerating or decellerating, or while turning one direction or another. The noise could be caused by several things....struts squeaking, strut mounting plates getting worn, dry or worn lower ball joints, rubber insulators between the spring and strut squeaking. Are there any lips or ridges at the top edges of the brake rotors? These can also cause a squeaking while turning, as it will cause the rotor to flex and rub the brake pad against the rust lip, causing a squeaking noise. Does it do it only while under motion, or even while stopped? This will tell you if it's something in the suspension or rotating assembly. As I'm sure you know, its extremely difficult to attempt to diagnose a car problem in this fashion. These are simply some ideas of things to check out. Is it a constant squeak while turning, or does it come and go....
(stupid visualization here)
squeeeeeeeeeeeeeeeeeeeeak....steady
or
squeak........squeak.........squeak..........come and go
Does it make the noise ONLY when turning, or all the time, just more noticeable when turning? As I said, there IS a possibility that it could be a wheel bearing...the symptoms don't sound right though, and for the cost and time to replace them, it'd be nice to be more certain before taking that plunge..
 Posted: Sat Jul 03, 2004 6:03 am |
justinwebb wrote: no its not the belt its coming from the general area of the tires...i have been told its my bearings that are squeaking and i don't want to have to tear it apart for nothing. Hi justinwebb, hello all
Check and adjust the belt, it's quick, simple, free, and probably due for inspection anyway.
 Posted: Mon Jul 19, 2004 12:20 am |
Take the front hubcaps off and see if it goes away.
85cieraholiday
 Posted: Mon Jul 19, 2004 8:21 am |
speedy266 wrote: hey u just replaced the alternator and power steering pump today and now there's a squeal when the wheel is turned all the way to one side, its constant, wats going on?? My car makes the same sound, I haven't figured out why, so I just don't turn the wheel 100% to one side when I can.
_________________ .
 Posted: Mon Jul 19, 2004 8:36 am |
85cierraholiday, if it only happens when you turn 100% of the way, its your power steering pump making sounds... Completely normal I think, most vehicles I've driven do the same thing.
Either that, or your belt is loose and when you hit the limit, the extra load on the power steering pump makes the belt start to slip.
