It is currently Fri Nov 20, 2026 2:33 pm
PostPosted: Sat Jul 03, 2004 11:45 am
Hello im having turn single problems they wont flash on there own i can manually flash them but if i but if i put the arm down either direction it just stays lit we tryed tried to put a new flasher plug but i did not flash i also lost all the lights on my dash, So now its real hard to see my speedometer the ashtrey light also went out, the clock recently just stopped turning and the fm in my radio went away. if any one has any ideas about any of these things it would be appreciated
PostPosted: Sat Jul 03, 2004 2:50 pm
when you manually do it, do all of the lights that are supposed to light up, actually light up? I know that a burnt out bulb or a bad connection can cause the flasher not to flash, but with your dash lights being out you may have more problems. How do your fuses look?
PostPosted: Sat Jul 03, 2004 4:55 pm
All of the interior light, and the forn went in my car, it turned out to just be a fuse, thats where id look 1st.
PostPosted: Sat Jul 03, 2004 5:40 pm
Images: 12
my friend had a camaro that had that problem, i spent about an hour tracing wires and replacing flasher box's checking every single bulb, but whatever id id, they did not flash on their own. he had to manually go up and down. never did figure it out... he has since totalled that pos :P
As far as guessing at stuff... Do as 73 Delta said... check the bulbs, and check connections. As far as dash lights... they 'might' be blown... my 83 delta blew its right side speedo light *lights up 55-85 points* replaced it, blew it again 5 months later... said screw it been like that for 2 years... but both would be hard. easiest way to check without ripping the dash apart.... ashtray light, you mentioned that went out. If that bulb is good, then you know you got another problem, if it is blown, then more then likely the speedo ones are blown *weird that both speedo ones went out at once* but hey, sh*t can happen.
Let us know how it turns out and and anything you find for future reference.
-Shadow's Rides-
