It is currently Fri Nov 20, 2026 3:05 pm
 Page 1 of 1 [ 8 posts ]
 Post subject: Tranny Troubles
PostPosted: Thu Jul 08, 2004 3:02 pm
My tranny has been acting up. It just stopped pulling. I left it in a parking lot that night. When I came back the next morning, the car went into gear and I made it about 4 blocks and it stopped pulling again. I think it may be a broken band, but I don't think the tranny is totally f*&^ed up. So does anyone have any suggestions on what is wrong.
PostPosted: Thu Jul 08, 2004 3:44 pm
Images: 8
What does the tranny fluid look like? Change the tranny filter too, that might help
Jake 19/m
1972 Olds Cutlass- Parts car
PostPosted: Thu Jul 08, 2004 4:02 pm
see if there IS tranny fluid... I had a caddy that did the same thing, but it was because there wasnt enough fluid for the tranny to pick up.
PostPosted: Thu Jul 08, 2004 4:34 pm
The tranny stick says it is full. I thought it was that also. And before that happened, my torque converter had unscrewed itself from the flywheel. I tightened it as well.
PostPosted: Sat Jul 10, 2004 12:20 am
how exactly does that happen and what happens when that happens?
1988 Cutlass Ciera SC
Torque(lb-ft)-215 @ 2750 RPM
Displacement- 3802cc
4 Speed Automatic
This WAS My Dad's Oldsmobile
PostPosted: Mon Jul 12, 2004 8:57 am
I would have to say that a torque converter unscrewing itself from the flywheel is not normal??? You may have some big problems...
PostPosted: Mon Jul 12, 2004 2:31 pm
9 out of 10 transmissions fail due to overheating. Thats why i just installed a tranny cooler on the weekend its sweet, really easy to install lots of space to with, i took of the front grile for better access i placed it in front of the ac condensor for 100% effencity. Read up on tranny coolers lowering the temp can double life of ur tranny supposely.
PostPosted: Mon Jul 12, 2004 4:17 pm
I think that on most V8s the torque converter is bolted to the flywheel by three pretty hefty bolts, not familiar with any that are screwed on.
