It is currently Sat Nov 21, 2026 7:06 am
88Ciera_SC
 Posted: Thu Jul 29, 2004 10:29 pm |
whats "cts" stand for..
my car does just the opisite..
start car..runs fine for about 10minutes then 1 of 4 things usually happens.
1.runs fine.
2.stalls at idle with no check engine light.
3.check engine light comes on and then dies at idle.with no codes.
4.car will jerk and then will be a very noticable lack of power and check engine light comes on and dies at idle.
if i turn the key completely off then back on the check engine light will go out..
right now i have the idle cranked up and helps alil with the just plain dieing at idle problem but if light comes on i'm screwed.
also engine races when i first start it so i'm most likely going to turn the idle back down alil.
I'm not completely car stupid but this one has really got me.
evything points me in the direction of a computer problem.
1988 Cutlass Ciera SC
Torque(lb-ft)-215 @ 2750 RPM
Displacement- 3802cc
4 Speed Automatic
This WAS My Dad's Oldsmobile
 Posted: Fri Jul 30, 2004 9:12 am |
88cierraSC,
Check engine light is on, idle is very high... Does it use a whole lot more fuel than before?
From what you say, when you turn your idle up, your problems lessen. Check out your TPS sensor. Same symptoms as mine had. The computer expects a certain voltage out of the throttle position sensor at idle, and if it doesnt see that voltage, the check engine light will come on, and the idle will shoot up, (simulates a 1/2 throttle environment just to get you home) and the car will run terrible, and use hellish amounts of fuel.
Its a relatively cheap part to replace. The computer wont flash check engine if the voltage is high enough, which would explain why it doesnt do it every time. Check that out.
If thats not the problem, try checking out your IAT (intake air temp sensor), apparently, when its not plugged in, or if it malfunctions, warm up will be greatly affected and may die at idle a lot.
Its too bad you dont have an ALDL dash computer... it will show you voltages real time for all these sensors!!! Even if there is no code, for example the TPS wont record an error code for you to retrieve, only will show an error while the check engine light is on, the computer will show exactly what triggered the light. Everyone build one of these, they are priceless on these late 80's fuel injected cars!
