It is currently Tue Nov 17, 2026 3:05 am
 Posted: Wed Aug 04, 2004 4:38 pm |
air filter... spark plugs... crappy fuel... ignition problems... Lots of possibilities.
Can you give more information about the loss of power? When does it feel not quite right? High RPM's? Full throttle? And when does the car sound louder? What kind of sound is it making versus what it should make?
Could be your catalytic converter, since I remember you had to replace a whole lot of exhaust stuff after it fell off? What exactly happened with that exhaust incident afterall?
88Ciera_SC
 Posted: Wed Aug 04, 2004 11:56 pm |
The very first thing i'd do is check for error codes.
if none then i'd start by,,
cleaning the throttle body,,
replace the plug WIRES..
when was the last time you changed your transmission fluid???
i used Valvaline Max Life in mine.
as far as being louder..i'd check for leaks in the exhaust first.
check all your hoses for vaccum leaks.
also start using Lucas fuel treatment..seems to be good stuff.
certainly doesn't hurt.
1988 Cutlass Ciera SC
Torque(lb-ft)-215 @ 2750 RPM
Displacement- 3802cc
4 Speed Automatic
This WAS My Dad's Oldsmobile
 Posted: Thu Aug 05, 2004 8:36 am |
Well, a bad exhaust problem will spread like cancer. It will get worse and fast if you dont fix problems with your exhaust. I dont know a whole lot about headers, but I have a feeling there is nothing wrong with them, unless the bolts are loose or something.
To me, it sounds like a plugged catalytic converter, because you are lacking engine response and its getting louder and louder... Exhaust problems I would say.
 Posted: Sat Aug 07, 2004 6:57 am |
speedy266 wrote: Is it normal for it to get extremely hot for idling for 7 minutes compared to the rest of the exhaust pipes? i can imagine it gets red hot when revving high.
Hi speedy, All
Its normal. It takes that much heat for it to work properly.
Replace it if it gets clogged or if you can't pass emissions test, otherwise, spend the money on better things.
 Posted: Mon Aug 09, 2004 9:39 am |
no catco = louder exhaust for sure... lots louder.
 Posted: Wed Aug 18, 2004 8:37 am |
coil pack going would result in misfiring or missing... you said its just a lack of power. Is it still running smoothly?
